2010 VX 150 D4D 65000Km review
  • 2010 VX 150 D4D 65000Km review
    After 2 years and 65000K thought I woudl drop some thoughts on the VX Prado.
    First off, the list of niggles, what's been fixed and what's still there;
    Overheating tranny problem sorted at first service with firmware update, no reoccurrence since.
    1500rpm resonance, took 4 attempts, but finaly sorted, adjustment of front mudguard finally sorted the noise, vibration remains, but that appears to inherent to the design.
    The piping on the drivers seat squab has worn, Toyota replaced it at the 40K service and then stated not covered at 60K service. I am a nerd, so i don't carry tools in pockets, keychains or anything else that might cause abrasion. I am 110kg, and the wear is where the seat folds as I turn to get out of the vehicle. My thought is that it is poor design.
    The bluetooth is selective about which phones it will pair with, refusing to talk to some Nokia and Samsung phones. This is a real annoyance, as I am about to change phones, and need to find someone who already has the phone I want to test it, as the phone companies won't exchange and don't have phones available to test it.
    The rear seats rattle and squeak, the squeak can be sorted with a bit of dry lube on the hinges and a dusting of graphite powder. A bit disappoint seeing this thing has barely seen a gravel road, let alone been off-road.
    Occasional flatspot at 2400rpm under mild acceleration, hard to replicate consistently, last service they cleaned the "hot wire" in the intake, still there.
    OK, so much for the grumbling, on to the positives;
    Fuel economy is good for a vehicle of its size, regularly get 9l/100km running between Canberra and the coast up and down Brown Mountain.
    Cabin is quiet, there is minimal noise while travelling, stereo is more than acceptable (according to the teenage contingent).
    I'm 6'1", and have plenty of leg room and headroom, stepson is 6'4" and he has leg room behind me. Have never used the third row seats, and not likely to, would be good if they were easy to remove, could use the storage space.
    We regularly tow 2 tonnes of boat & trailer, 3.2M high hardtop, so lots of windage, can happily sit on 110 where speed limits allow, although find the economy much better at 95kmh, with an avge of around 14.5l/100km return from Canberra to Bermagui and back on the computer, and a real 15.5 at the bowser.
    The 150 litre fuel tank is great for a weekend away fishing, we leave on a full tank, do a weekends fishing and not have to worry about being back in before the servo shuts, normally around 700k's all up. Convenience factor for us is huge.
    Bought when Toyota were offering their Service Advantage program, so all services to date have been $200, guess the next one may be a shock.
    Overall the ride is great for a vehicle of its size and bulk. Handling at highway speeds is acceptable, and from a test drive in a GXL, the KDSS justifys some of the additional cost (still struggling to justify the extra all up, but it is a lease so the pain is eased a little).
    Original tyres still going, but have noticed started to "track" over the last 2K. Not the greatest in the wet, but wear has been exceptional and not noisy. Looking to replace them with a set of Cooper HT/Plus based on recommendations received. Being a busy person, tyre rotation sort of got overlooked, and the first wheel alignment will be when the tyres are replaced, probably around 70K. Tyre wear is even, and looking good for 70K before the wear limits, a good result given the number of roundabouts in Canberra.
    Front brake pads were replaced at the 60K service, quite happy given that we tow and do quite a bit of mountain travel. I tend to use the gearbox, but my partner relies on the brakes, and sometimes its nice to have a beer and enjoy the journey. Have had no issues with brake fade, even on occassions where I may have been in a bit of a hurry down the mountain.
    Parking sensors and the reversing camera make an otherwise unwieldy town car quite usable. Parking is easy once you get the hang of the sensors and the offset on the camera.
    Have not had to add oil between services, usage has been minimal. Make a point of requesting that the jack shaft is greased at each service.
    Performance is not amazing, but sufficient to be able to travel safely. Overtaking is ok, but I like to have a clear run. It is a diesel after all. Happy to be patient, and have to be careful, exceeding the posted limit while "cruising" is a little bit easy.
    Overall assessment given the purpose is 40% commuting, 40% travelling 600K return and 20% as a tug, is very good. Yes I could fill these requirements for less money, but with a requirement for a large car to cart an industrial sized family, Seats that would resist fishy contamination at the boat ramp, but so far, total cost of ownership is looking a reasonable proposition.
    To date I am a very satisfied customer, yes there are some small niggles, but uinctionally the vehicle has delivered everything expected. It is pleasant to drive for a three hour stint, and quite comfortable even after 1000 k's. I can't comment about 4wd capabilities, has never been off-road. For a large family car with a reasonable towing capacity it's a good gadget.
    Hope someone finds this useful.
    thylacene
    Interesting sumup thylacene but you've not had it off road yet ? If you do you'll see that it's a good dual purpose vehicle .
    Ross
      Ross
      I have no doubt that the 4wd capabilities are there, but worked in the bush long enough that getting bogged and winching aren't my idea of fun. It has made keeper stakes though, can see me buying this one out of the lease and hanging onto it for some time.
      Maybe when I retire I'll find time to test it out ;^)
      Life is too busy and when time is available, fishing takes precedence.
      Thy
        I too have done 65k in my VX now and have had no such engine complaints because I bought a 202kw petrol. I like the revving power of a modern quad cam. I also tow a similar boat and am able to pass safely when I hit the load pedal. Average fuel usage by the computer is 14.9L/100, which considering the discount cycle of the E10 fuel, I am happy with.
        The seat piping is interesting as i have the same issue, very disappointing as you see it every time you go to hop in. Maybe a permanent black marker will be employed this weekend, now you mention it.
        I have been told the 70k service is only $260 , but the 80K is the big one with all fluids changed and some major tinkering @ about $650.
        I have enjoyed the easy touring on dirt roads & tracks (finke gorge, Birdsville. Oodnadatta track & The Flinders) and with the tyres down to 26 psi have had no troubles even with the grandtreks. Likewise sand work @beachport and robe have been a hoot if you are happy to bury ya foot in the carpet.
        I would certainly recommend it as a grande tourer for our country, and all the mods are available if you want to go rock hopping.
        150 VX Petrol, Cooper AT3's, Redark DC/DC charger/dual battery system, Airbags, Airtech snorkel, Waeco cf50, Challenge campomatic-offroad
          Good review Thy, mines a GXL (prefer to have my off road capabilities in my hands than a computer). I have just had the 40K service done (literally today)...no great issues. I put seat covers on (the Toyota ones) so don't have that issue.
          Good to see the Grandtreks have lasted that long, I changed mine immediatly to BFG's as it suits my "zero commuting" 60% touring / 40% off road needs better.
          Looks like I too will be rolling up for a 60K service before long as I have Cape York in July and the CSR next year about the same time.....that's another 20,000 without even the occasion "other trip"
          But thanks and a great read!!
          150 Silver Diesel GXL Auto with ECB Bullbar, Toyota Factory towbar, Black Widow Drawer system with Fridge slide and cargo barrier, GME UHF 3340 Radio, Waeco 50 Litre Fridge, Rhino Racks and Rhino Basket, ARB Awning, IPF XS Spotties, ABR Sidewinder Dual Battery system,Airtec Snorkel, Bilstien Shockies, King Springs, Poly Airbags and BFG A/T''s. Now towing a semi offroad Lotus Freelander 18.6 Van, with all the bells and whistles.
            Yep, horses for courses, never thought about it until after the deal was done, would have had the dealer swap the 18's for 17's, glad they have lasted. Odd size means low volumes and higher prices. I am a Scrooge at heart. The choice of the VX was part ego, and part that I have never sat in a set of seat covers that haven't annoyed me. I am industrial sized, they always bunch up wher I twist to get out.
            They are a comfy truck, eats up the miles, relatively quiet, and very civilised. The petrol would have been nice, but towing on mountain roads the diesel suits us better, and no complaints about performance, it did overtake an Impreza coming up the Brown Mountain, dozy tourist sightseeing at 40k's. With 2 tonne behind it the speed limit is still very achievable. We picked the boat up from Melbourne and drove straight through to Canberra, set the cruise control at 110kmh, and found that there are two hills that force the gearbox to kick down to third, and cancels the cruise control between Melb and Yass, and it will hold fourth but not 110 Kmh, I am happy enough with that. I budgeted 300 mth for fuel, the petrol would have been another 150, plus the xcess kms I have run up with some unplanned trips.
            I bought it intending to renew the lease at the three year mark and renew for another 4, as the maths made sense, but the govt have changed the rules, so will reassess closer to the date. The premium for diesel becomes cost effective around 70000 k's if you can live without the fastest 4wd. If dollars weren't an issue a 200 series would be my choice, but in reality overkill for the needs.
            I would like to think that with predominantly highway and commuting that 400,000 k's is a realistic life expectancy for one of these before the maintenance overhead becomes too high.
            It still feels " tight" at 65 k, so fingers crossed.
            If it makes it that far without mechanical catastrophe it will be bloody great value.
              Good review, thanks for that.
                I am on my second Prado, first GXL 120 did 120000k love it, new 150 GXl has done just over 20k love it, both were petrol, don't tow much so would rather have the power of the 200 killer wasps,
                I have owned heaps of cars over the years including V8 statemans etc and I think the Prado beats them all.
                [b]Rob[/b]
                  I had this issue too, i took it in to my dealer who shrugged their shoulders at the problem until i got chatting with one of the mechanics who has a Prado too. He said he had the same issue and was told by toyota that it didn't exist for 2 years until they brought out a fix for it. Then they said "oh yeah that problem" Typical Toyota crap!!!
                  Anyway the fix is there for it and it's just an ecu tweak which adjusts your rail pressure, i was told they just up it by a beez dick and the problem is gone. Mine has been fine ever since i've had it done which was about 10,000kms ago.
                  If you have problems getting an answer from toyota ring Sunshine Toyota @Curramundi (sunshine coast) and ask to speak to Luke (the mechanic) about it and he'll be able to tell you the Toyo code for the fix.
