They still haven't overcome the lack of range. Most electrics are only capable of around 80km. You'll end up stuck in the outback a long way from a charging station.
Will we get hybrid Prado`s in the future?
Electric motor on each wheel is the ultimate. It'll only be interesting if it's made by Land Rover or VW, Toyota can keep water out of electricities no problem.
Imagine the engineering simplicity: no gearbox, transfer, drive shafts, diffs, CV joints; suspension will be simpler, cars will be lighter despite the batteries.
Imagine the precision of traction control.
Internal combustion is only still around because the multi millionaires demand it.150 D4D GX with big tyres, TPMS, Tracklander, GME, Safari breathing straw & super soft squishy custom rear springs.
Hey all,
The biggest problem with hybrids is the battery materials. First order estimates suggest there is nowhere near enough transition metals, rare earths or light metals to outfit the worlds vehicle fleet.
It's actually cheaper to produce hydrogen (a highly energy inefficient process) and retrofit existing combustion engines to run on hydrogen and use lightweight carbon reinforced tanks.
Most hydrogen vehicles on the market now have ranges over 500km.
I can imagine a hydrogen powered 4wd in the future that can go anywhere with a mobile solar electrolyser that splits water and produces hydrogen to create more fuel in the middle of nowhere. You might have to carry extra water, but this is just the same as carrying extra fuel.
Interesting times ahead!
Best
https://www.whichcar.com.au/car-news...g-in-australiaOriginally posted by Whitey View PostHey all,
Best
Mark[I]Maroochydore, Sunshine Coast, Queensland[/I]
Whitey
