safari snorkel query
  • safari snorkel query
    hi
    just a quick question
    if i cover the snorkel intake with a bag should the engine stall
    or how do i check to see if the snorkel has been installed correctly
    Daniel
    Don't cover/block it.
    Remove the plastic guard liner and have a look make sure hoses are well on and clamps are F tight.
    Have fun with those funny little square Toyota clips!
    Check the small drain hOles in bottom of airbox are sealed.
      thanks
      will i need to remove the wheel as well to remove the guard
        Another way to check is to remove the 'head' from the snorkel and put the palm of your hand firmly over the snorkel. You should feel it suck on your hand and the engine start to labour. That would mean no air is getting in from anywhere else.
        150GXL 3.0D4D Auto, White, ARB Deluxe Winch Bar, iCom ic440 Pro UHF, Safari Snorkel, Rhino Bars and Platform Rack, Dual Battery System, Brown Davis underbody protection, Cooper ST MAXX Tyres, Lovells Springs & Shockers & 2" lift
          Mine does not have small drain holes sealed. Do you seal with a silicon that is suitable with air sonsor or is there another product?
          Peter
          150 GXL D4D Auto White
          ARB Bull Bar, Toyota Tow Bar & Cargo Barrier, Anderson Plug, Prodigy, Window Tint, Icom 440 UHF, Snorkel (Toyota/Safari), Waeco CF50, Jayco Eagle Outback
            all seems good on the snorkel
            thanks for your help
              I use ultrablue/bluemaxx.
