Make sure you ask for the under bonnet diesel fuel filter to be replaced. It's not a sheduled service item and won't be changed unless you ask or the fuel filter light comes on. Had the 80,000 k sevice Thursday, wife had to go out west on the Saturday . 30 min into a 1,000k trip get a phone call, fuel filter light came on, meet her, drained sediment trap, light stayed on, swapped cars, not happy. Took Prado back to dealer Monday morning,yep blocked main fuel filter. Funny thing was the guy i was sitting next to in the dealers waiting room had exactly the same thing happen with his 200 series diesel cruiser,80,000k service on Thursday and all. When i talked to the service advisor, was told a few customers ask for the filter to be replaced, generally every 40,000k. Seemed like my scenario was not new to them. Suggested they should advise customers about the issue but they didn't seem too interested. Anyway rang Toyota Customer Experience Centre and related my bad experience to them. Sounded like they had heard it before, just like the 1500 vibration.
Main Diesel Fuel Filter. Ask for it to be to be replaced at service.
thanks Jeff,
How much did they charge you for the filter?SE Qld: GX 150GD Auto, (Feb'16 build): TJM T15 steel b bar, 9,500lb TORQ winch, TJM s steps, Rhino Pioneer Platform (42102B 1928X1236mm), front recovery points, Wynnum towbar, P3 brake controller, TNN Underbody guards, UHF, TREKtable & LED striplight, Custom Fridge & Drawers, Waeco CFX50, 9inch illuminator 160W LED spots, 40mm lifted Dobinson Suspension (Zordo's), ScanguageII, 30 Sec Wing Awning
Mine gets changed every 10,000km......[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][CENTER][SIZE=2]
[/SIZE][/CENTER]
I've drained mine before but how do you replace it?
Is it a matter of removing the hoses/sensor and plugging it into the new filter?
What are the possible newbie mistakes? Will Diesel go all over the place? Will there be issues with priming?
I know ... too many questions for a Monday evening.
Cheers[COLOR="black"][b]William[/b][/COLOR]
Having spoken to the dealer and service manager I used to work for he recommended every 40,000 km for the under bonnet filter.
Personally installing pre filter to take the bulk of the nasties out allowing the genuine filter to finish the job can't be a bad idea. On the other hand it's been suggested to place the additional filter after the genuine so the genuine can notify you when there is contaminates in the fuel.
Either way clean fuel is a must for modern diesels so an extra filter change will always be a good thing. Also keep a spare handy.
HazzaSilver 120 Series Diesel GXL 2009 with Option Pack 2, king Springs 2" Lift with 'H' front spring, MT ATZ 4-RIB, Dual Battery, Deluxe ARB Bull-bar, Winch, Towbar, Anderson 50 amp plug at the rear, Weather Shields, Bonnet and Head Light Protectors, Rubber Mats inc Cargo mat, UHF Ariel, Portable Uniden UHF plugs into areal, On-board ARB Compressor, Brains Black Box TG150 Protector, Rear Black Duck Seat Covers.
Interesting. I recently travelled to Sydney from the Canberra Region. The car had 45,000Km on it, and what happens half way? Yup 'Fuel Filter Maintenance Required'. Anyway, it was 0530 in the morning, and I had to be at the International terminal at 0700, so I kept driving (and the owners manual didn't elaborate too much on it).
Anyway, in Toyota's defence, as soon as I got back from overseas, I called the closest dealer, and they sorted it out for me in minutes.
The service centre said that there was a lot of water in the filter, and it was probably from a bad batch of Diesel. I've just moved semi-rural, so it could be true... but it is interesting that it happened at the 40,000Km mark in line with comments above?!? He also said that it if it happens again, get the filter changed... so I'm confused about whether it was the filter or the fuel... but a few weeks and 5000K later, it hasn't happened again.2011 Crystal VX 150 | ARB Deluxe Combo Bar | Safari Snorkel | IPF 901XS Driving Lights | Cooper A/T3 265/60R18 | Hayman Reese H/D Tow Bar | GME TX3540+AE4702 UHF | Warn XP9500 Winch.
On a 200 Series, if the warning light comes on solid, without any audible alarms, it signifies that the filter is partially blocked. In which case you can keep driving, but can expect suboptimal performance at full throttle overtaking because the filter is not allowing fuel to pass through the element quickly enough.
But if the warning light is flashing followed by the audible boing boing chimes, immediately stop at the side of the road, as the sedimenter trap has detected the presence of water.
Not sure whether this is the same warning behaviour for a Prado 150 Series, but I'd imagine it'll be the same.
Talked to a guy at work who owns a 09 hiace D4D about the main fuel filter being not included in the service shedule, so he checked his service book and guess what? No shedule for changing any fuel filters on the diesel! Interestingly i mentioned to him that at 150,000k the fuel pump is to be replaced in the D4D prado according to the schedule. When we checked the hiace D4D service shedule there is no mention of replacing the fuel pump. Strange. Any ideas? Wonder what is in the Hilux service shedule for D4D equipped vehicles.
On the 150 Prado when the fuel system warning light flashes and buzzer sounds....stop and drain the fuel filter sediment trap immediately. Page 470 of the Owners manual shows you how to do this, its easy. You turn the nobbly drain plug located under the filter about 2 and a half turns anticlockwise by hand. Pump the prime pump on the top of the fuel fiter assembly and flush the sediment trap. Retightern the drain plug by hand. Put as small container under the filter to catch the diesel. In fact this should be done every service, however it is easily overlooked, so do it yourself. If the light/buzzer comes on whilst driving just pull over and drain the filter asap, no need for a container, and just flush the filter and all is ok. (Personally I would then change the filter/sediment accumulator at the next convenient time.) Toyota recommend that the petrol Prado have their fuel filter changed at 80,000km, but not on the diesel model...I know there is a fuel transfer filter under the car which is changed every 20,000km but why not the main filter/water sediment accumulator?
According to the Servcie schedule, at every service the "water sediment accumulator" should be "inspected"...that can only be done if it is drained and the diesel that comes out is inspected for any water.
Interestingly, and just as an aside, before a flight and after every refuelling, aircraft pilots open a fuel drain point on an aircarft and uses a special paste or a special indicator that changes colour if there is water in the fuel because the water is not always visually obvious if it is mixed in with the fuel, and obviously they don't want an aircraft engine splutteing or stopping during flight if water gets into the system.....well, I'm not doing that every time I refuel the Prado, but I do drain the water sediment accumulator occasionally and give it a flush by pushing the primer knob a few times just to be sure there is no water or crud in the filter.Last edited by brogers; 17-10-2012, 08:30 AM.SE Qld: GX 150GD Auto, (Feb'16 build): TJM T15 steel b bar, 9,500lb TORQ winch, TJM s steps, Rhino Pioneer Platform (42102B 1928X1236mm), front recovery points, Wynnum towbar, P3 brake controller, TNN Underbody guards, UHF, TREKtable & LED striplight, Custom Fridge & Drawers, Waeco CFX50, 9inch illuminator 160W LED spots, 40mm lifted Dobinson Suspension (Zordo's), ScanguageII, 30 Sec Wing Awning
;-) . An aside close to my heart. Yes... the paste/indicator IS the legal requirement (and probably a must when flying out bush getting fuel from drums). In practice, most just hold it up against a white surface to check that there is a tinge of blue (color of 100LL AVGAS). If there is a small amount of water, it will look like bubbles down the bottom of the tester. A full tester of water is harder to detect (a real pain on a cessna 310 with 9 drain points).Originally posted by brogers View PostInterestingly, and just as an aside, before a flight and after every refuelling, aircraft pilots open a fuel drain point on an aircarft and uses a special paste or a special indicator that changes colour if there is water in the fuel because the water is not always visually obvious if it is mixed in with the fuel, and obviously they don't want an aircraft engine splutteing or stopping during flight if water gets into the system.....well, I'm not doing that every time I refuel the Prado, but I do drain the water sediment accumulator occasionally and give it a flush by pushing the primer knob a few times just to be sure there is no water or crud in the filter.2011 Crystal VX 150 | ARB Deluxe Combo Bar | Safari Snorkel | IPF 901XS Driving Lights | Cooper A/T3 265/60R18 | Hayman Reese H/D Tow Bar | GME TX3540+AE4702 UHF | Warn XP9500 Winch.
Sounds easy to drain the sediment trap but in reality it's not that simple. When I did mine the other day I ended up removing the two assembly mounting nuts and tilting the whole assembly. There just isn't a lot of room and just try to catch the waste diesel ! In an earlier life I was a diesel mechanic ,so this was no big deal but its not as easy as described in the Toyota handbook.
Maybe the knob underneath the filter had been done up too tight prerviously, and whilst there isn't heaps of room, I certainly don't have any problem, seriously. I use a small ice cream type container and catch the diesel, but anyway, I didn't find it too bad, and certainly didn't have to take the filter mounting bolts off and tilt the whole assembly....maybe there is some variation between Prado models....I'm not sure what vehicle yours is Jeff as it seems you haven't put any info in your signature area, but, just maybe, there are some slight differences sufficient to make it more difficult in some models than it needs to be...perhaps?SE Qld: GX 150GD Auto, (Feb'16 build): TJM T15 steel b bar, 9,500lb TORQ winch, TJM s steps, Rhino Pioneer Platform (42102B 1928X1236mm), front recovery points, Wynnum towbar, P3 brake controller, TNN Underbody guards, UHF, TREKtable & LED striplight, Custom Fridge & Drawers, Waeco CFX50, 9inch illuminator 160W LED spots, 40mm lifted Dobinson Suspension (Zordo's), ScanguageII, 30 Sec Wing Awning
