Facelift for 150 series prado
  • Looks like this might be the first carsales.com.au advert for the new Prado:
    http://www.carsales.com.au/bncis/det.../?Cr=1&sdmvc=1
    Only one image for now!
    2014 Toyota Prado 150 D4D Auto (facelift); ARB Deluxe Bullbar; OME 2" Lift; Rhino Pioneer Platform Rack; Redarc BCDC 1225 with Optima Yellow Top; BF Goodrich Mud Terrain KM2; Lightforce Genuine Custom 70w HID; GME UHF; Safari Snorkel; Rigid Industry SR-Q2 side lights (yet to be installed); Domin8or winch (yet to be installed)
    • Here's Toyota's email response to my question of "Do the new VX & Kakadu Prado's have KDSS".
      Good Morning,
      Thank you for your recent email received by the Toyota Customer Experience Centre.
      You will need to liaise with your dealership if you are requesting specific information which is of a technical nature.
      Technical experts are within our Toyota dealerships and have extensive knowledge that may be particular to customer’s needs and wants.
      Thank you for contacting Toyota and allowing us the opportunity to respond.
      Kind regards
      That's a pretty pathetic answer...
      • Originally posted by peter_mcc View Post
        Good Morning,
        Kind regards
        They pretty much should have sent you the first and last line only and you would be just as informed LOL
        [/CENTER]
          Good Morning,
          Kind regards
          [/CENTER]
          • Originally posted by Symo View Post
            This info is in the toyota website.
            • Originally posted by Bonito View Post
              Do you mean the KDSS info? If so, where is it? I looked at the VX turbo diesel specs and it doesn't mention KDSS. It's not mentioned as something additional for the VX or Kakadu. And if you ask it for the differences between a GXL and VX there is no mention of any suspension changes!
              Peter
                Peter
                Mate in the website, under suspension, it is called adaptive variable .....with 3 setting levels...this is the KDSS. It is under kakadu specs
                  Under the VX, there is no mention of KDSS, just coil springs
                    I thought the adaptive suspension in the Kakadu was something else - that you could set how "hard" it was electronically. I gather this is done (in the back at least) by replacing the springs with airbags.
                    • GXL metallic paint TD auto drive away $64500....VX $79000 that's the first price.... That's before a 12K trade on a 2007 Mazda CX& with 177000Km on the clock. So change over $52500
                      • Originally posted by Sprocketz View Post
                        Did you get that price from a sunshine coast dealer? any mention when the stock will be arrive?
                        • Yes plenty of stock coming in before xmas lot's of VX at Sunshine Toyota and Ken Mills
                            The adaptive suspension in the rear is not KDSS, it appears Toyota haven't listed KDSS in the specs
                            Dan
                              adaptive variable suspension is what the member listed below although I don't think the Kakadu's have airbags. There would be a soft, normal and sport setting for your drive.
                              Found this:http://ask.cars.com/2008/10/what-is-an-adap.html
                              KDSS is an entirely different beast (active suspension?), relying on accumulators/or actuators to raise the suspension or dampen the roll of the car out. Easy to see how the two could get confused though. KDSS has not been listed as DSS150 ^ mentions.
                              • Originally posted by macaroon1 View Post
                                I can't see why they wouldn't, my 2009 Kakadu has airbags in the rear suspension setup. My shocks have sport and comfort settings from inside the cabin, it works by adjusting the valving on the shocks via an electronic link/control.
                                KDSS controls a hydraulic ram on one side of the sway bars, the other side is fixed. At least that's the way it works on my Kaka.
