I have just received my eTag toll pass to use on CityLink and EastLink and I'm not sure if it's ok to mount it in the usual spot next to the rear view mirror. I believe the thin box to the left is the rain sensor for the wipers. Is the eTag likely to cause interference with this or anything else up there?
Where to mount eTag?
Mine is mounted behind the rear view mirror... No problem with any interferenceOriginally posted by fido666 View PostI have just received my eTag toll pass to use on CityLink and EastLink and I'm not sure if it's ok to mount it in the usual spot next to the rear view mirror. I believe the thin box to the left is the rain sensor for the wipers. Is the eTag likely to cause interference with this or anything else up there?
Jeff[SIZE=3]Jeff[/SIZE]
Which one? Am fm or UHF, the am fm is in one of the back windows and the UHF comes through the firewall drivers side. Why do you ask?Originally posted by fido666 View PostOK, thanks Josh. Stupid question perhaps but where does the radio aerial run?150 with stuff bolted on!
I only opened the account so I could come to your place Anthony :-)
Bloody GPS took us another way and we didn't end up using CityLink to get to you but we did use it to get home, beats going through the city or down Kingsway. I won't be using it if I can avoid it but sometimes it's just faster and less hassle to go the toll road route.
Move to South Australia, no toll roads here
(yet)
Left hand side of rear vision mirror on dotted panel. Works fine.Prado GXL 2012 Charcoal - Drifta Drawers, Cargo Barrier, Sidewinder Dual Battery kit, Ironman Bar, Narva lights, Safari Snorkel, Airbags, TX3350 kit, Waeco CFX65DZ - often seen with Thule 2.2M narrow roof pod and towing 2014 Kimberley Kamper. Could be anywhere!
In the bin between the front seats? Wouldn't work for me since mine is also a cooler box which gets quite icy, not good for electronic devices. I'll probably just put it up behind the mirror as others have suggested, that way it's out of the way.Originally posted by mrkrinkle View Postkeep it in the centre console storage area and it beeps fine
