Air Conditioner Pollen Cabin Filter
  • Air Conditioner Pollen Cabin Filter
    Hi All,
    Just replaced the air con filter in my 150 mine spec GX - I think it had half the Pilbara in it, even though the previous filter was dated 2012.
    Never the less, it explained my weak fan strength and the pong when turning on the A/C. I cleaned out as much gunk as I could and blew air through the vents and fan - sprayed Glen 20 into the intake fan and on the new filter.
    However, after half a day the "Pilbara Smell" has returned (only faint though). I did read on a 120 Series post it took a guy a couple of weeks to get rid of the dusty smell in his air con - have also read about Wynns Airco-Fresh http://wynns-otobakim.com/product/airco-fresh/58.aspx
    Spray AIRCO FRESH in the fresh-air inlet (which can normally be found in the engine compartment at the passenger’s side) - where exactly is the fresh air inlet for the 150 diesel? I couldn't locate it easily... I found a black duct going into the vicinity, but it looks like I will need to pop it off further down the line (if it is indeed what I am looking for....)
    Can anyone provide a picture?
    EDIT: I probably should also ask while I am here - the 120 series had a plastic frame the filter sat in. My 150 didnt have this - It seems a different filter. Can anyone else confirm they also do NOT have a plastic frame.
    Kevin
    shodown
    Hi Shodown The 150 has no plastic frame,even under normal around town use they look very dirty after 10000km Regards a1mbm
      Hi Shodown
      The original filter in my 150 had a frame all the other from toyota didn't, now its out of warranty I service it myself after market cost $20
      2016 ISUZU DMAX TWIN CAB.
        Anyone have any comments on differing brands? Found one as cheap as $20 from Veale, some just as expensive as OEM. Went midrange on a Ryco for $30 in the end.
        Also, does anyone know where the external air intake is for the air con?
          Can someone tell me where this pollen filter is located please ?
          Cheers Ross
            Just behind the glove box , the glove box just pops out
              mine has a hole in it! where a rodent has chewed it, the new one now has bait on top of it to get the little bugger.
                Bear63 thanks mate , I'll have a look behind the glove box .
                Cheers Ross
                  Cheers Ross
                  Its in your owners manual
