ARB roof rack - installing the mounting rails
Wrong way! These legs face in not out.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
No but it will bend down ok. Are you sure they are seated correctly? I used sinkaflexed between the roof and rubber gaskets and in the holes. Do you have the instructions from ARB?
Jasen it is rail one per side.
EDIT: I should have the instructions. pm me an email address and I will send them if you don't have the paperwork.Last edited by mjrandom; 29-06-2013, 08:09 PM.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
email on its way. Looking at the second pic the only thing I can think of is that the little tubes that protrude through the roof channel are squashed under the ARB foot. Make sure the tubes are through the holes in the feet. I remember that some of those tubes on mine had been presquashed so you can use a pair of pliers to get them round again and upright!
Actually reminds me of the Tigerz-11 things that mmr had. They fitted all over the place but the ARB rail is much better and mine went on almost perfectly straight.
Jasen the rails look mostly like this, mine were edited for bad behaviour.
Bear in mind I stuffed with mine and modified the rails and mounts and used a non ARB rack but it should look a bit like this.Last edited by mjrandom; 29-06-2013, 09:22 PM.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
When I installed the ARB rails on my 120, they were almost level, not angled up. The tubes need a little straightening some times as mjrandom said and the ARB seals need to be stretched slightly around the outside of the tubes so the rails seat correctly and the seals set against the roof.
Putting the rails on is the easy part, compared to fitting the nut plate under the middle mount on the rails. From memory my son and I ended up taping the nut plates on to the rails before dropping the rack over the top. Even then, we had to elongate some of the holes in the rack to line everything up. It is a great rack but the design of the mounts is poor
Cheers........wayneWhite 2012 GXL 150 TD Auto. Work in progress. Aiming to spend less than when I kitted out the 120!
If they are arb ones, they can only fit one way based on the width of the mount points. Would pay to silicone around the existing tube bits surrounding the bolt holes toa, as i found out the hard way that that can tend lo leak otherwise. When i put mine on they didn't sit right until i had tightened all the bolts down.Last edited by Smithy - 120 D4D; 29-06-2013, 09:48 PM.2009 White KDJ120R Manual fitted out for family camping and touring - See my Rig Build at [url]http://www.pradopoint.com/showthread.php?27887-Smithy-s-Rig-Build[/url]
Thanks for all the replies, Im starting to doubt if i got the right ones.
(MJ thanks for the email, the instructions I received were black and white – the colour is definitely a lot easier to follow.)
The ones in the manual and all over the internet i've seen are a C channel section, whereas mine is like a Z profile... (the bottom curls).
I might take it off one more time double check the tubes to see if they are coming through the rail seats correctly,
BTW - my rack is a ARB touring rack (if that makes any difference)
That's weird, while I haven't seen the 150 frame I would expect it to be a C section like the 120 and others and not a Z as you have. Did you buy the gear from ARB?My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Hopefully someone who has the rails fitted to a 150 can jump in otherwise give ARB a call Monday.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
I have a 150 with ARB rack and the rail is a C section, Not a Z as you have been supplied.
Alan[color=#0000BF](The MK II) 2012 GXL Auto Diesel, White, ARB Bull Bar, Warn 9500lb XDC Winch, ARB Alloy Roof Rack, Aussieoutdoordirect Awning, Toyota Tow Bar, Safari Snorkel, ORS Rear Drawers and Fridge Slide, ARB Battery System with REDARC isolator, ERPS 10 Pad electronic Rust Cont, 275/65/17 BFG AT's, Jumbuck Sheep Skin Seat Covers, REDARC EBRH Brake Controller, OME 2" lift kit, Air Bag Man high pressure air bags, ARB CKMA12 on board compressor.[/color]
G'day Su888 I fitted mine the same way.... it makes a perfect fit in the gutter the laser cut writing on the rails faces the right way.Originally posted by su888 View Post
