Just in case you are running the standard tyres still, bear in mind that their maximum pressure is 51psi cold.
I still run the standard tyres, generally around 40psi when towing. The van tyres are LT and I run those at 50psi. On last trip of 6139 km Melbourne to Birdsville and surrounds and back with van at around 1400kg +/- used 823 Litres for a calculated average of 13.4L/100km.
I use D and S4 depending on terrain as others have noted.
I have TPMS fitted and the above pressures fit in with the 4-6 psi rule.
Prone
Prone
