  • Full service
    -Engine oil,front and rear diff oils,transfer case oil,brake fluid and coolant flush and lube driveline.Replaced oil,air,fuel,a/c pollen filters and full set of wiper rubbers,road tested all okay and no water from the recent flood waters,auto oil next service.
    • Fitted Toyota roof rack on my kakadu
      • Major service on "Shorty" ZR. All belts (inside and out) all oils replaces n flushed. Ran more that 2K kms around NSW and went like a dream. Money well spent. Need handbrake tightening though and apparently that is an expensive job due to removal of front pass seat and centre console. Any ideas anyone??
        • You could do it at the wheel maybe?
          • Remove passengers seat???
            Just have to remove the centre console upper trim and adjust the cable with a 12mm spanner, 15min job.
            The handbrake should be adjusted at the wheel first though.
            [LEFT]Silver 150 Facelift
            • It's a DIY job yeah. Don't need stealership mechanics to charge you a gazzilion bucks just to adjust the handbrake
              • Lifted it, have to wait till it settles to see how happy I am
                • Originally posted by kenny5000 View Post
                  What did you install Kenny? Do you have any pictures or measurements? Also accessories ?
                  Cheers Matt
                  Rig build here
                  • Finally after 7 months I took of the dicky rear wheel cover!
                    https://www.flickr.com/photos/derekandsue/17805647639
                    Derek
                    [SIZE=1][I]Life's too short... Get out there!
                    2014 Prado GXL D4D Auto / 2011 Trackabout 4x4 Deluxe Tourer Camper Trailer[/I][/SIZE]
                    • Make sure you scrub the blue stuff off the writing. Once it gets some UV it goes hard. Looks good.
                      • Thanks for the tip @mjrandom. Will do.
                        Derek
                        • Originally posted by Mattfunk 120 View Post
                          Cheers Matt
                          G'day Matt, I just went with an OME - 50mm at the moment as I didn't have time to sort anything else (I am leaving Darwin in the next couple of weeks and heading Sth for work and wanted to road trip and see some sights). I might look at something else once the build is finished. I will post the measurements in the Suspension section as well as a pic! I took it out for a run today and it went quite well.
                          • Went camping for the weekend with the clan at Gordon Country near Warwick. Took the 150 and the 90 and sons FJ40
                            Sunrise Is apparently something only older people see.
                            Quick group shot before the big descent
                            Lets take the photo with some leaning trees to make it not look steep
                            After a dirty weekend the lady needs a bath
                            Session debrief
                              It only took a blast from the hose to get the blue coating off mine.
                              • Brand new 2015 prado gxl with OL colour coded bar and tow bar. Today I fitted arb batt tray, Racq AGM battery, redarc isolator, lees diode, ran cable and fitted Anderson plug at rear also ran separate cable for dual 12v sockets hidden in rear as well as a set of fyrlyt on the front those lights are the bomb.
