Originally posted by Geoffury
View Post
No they don't come with a quick connector plug, which is annoying. I'd gladly pay the extra $20 ARB could charge for it,Originally posted by Bailey84 View PostWere the LEDs plug and play or did you have to cut and join the wires?
Just to make it easier.
So what I did was cut the original cable 100mm back from the connector, join the cables, you do just need to seal off 1 of the original earth wires, and then used the connector.
Took about 30 mins to do each side, including changing the fog light bulbs,
and adjusting that wiring also, once I had the wings off.
Looks good now, and I won't have to replace those damn bulbs again now.
Geoff
Can you give us an update in a few weeks please, lots of stuff on forums about this. I reckon there should be a class action to make Toyo fix all these.Originally posted by gavinvbrf9 View PostGot dynamat professionally fitted to the drivers side wheel arch to address the 1500 RPM drone. Seems to have worked so far as it sounds quieter.
Hi Ozimacca, drove 60 kms today to work round trip, must say it is much quieter at all speeds and you have to check the TACO to see what revs you are doing, as mentioned in another thread, I have a small dash vibration now, now motor is so much quieter. Waiting on reply about the small plastic tab at the bottom of the windscreen that may be causing it. Otherwise much nicer environment to be in
Thanks for the reply, if you were able to fix it maybe Toyo ought to get off their b*ms and do the same for anyone who has the problem !
Mine is only new and no problem yet but I it is so common that I wanted to check how you went, I have saved your post just in case mine starts it.
Originally posted by gavinvbrf9 View PostHi Ozimacca, drove 60 kms today to work round trip, must say it is much quieter at all speeds and you have to check the TACO to see what revs you are doing, as mentioned in another thread, I have a small dash vibration now, now motor is so much quieter. Waiting on reply about the small plastic tab at the bottom of the windscreen that may be causing it. Otherwise much nicer environment to be in
That is good, mine is 6 years old, so vibration can be anything, Give Simon a call at Newcastle Pro Sound in Jesmond, for $100 and $15 for seven trim clips for the wheel arch plastic (bought from toyota) you will have a quieter vehicle - their phone number is 4965 6899. They are professional installers. I am no way affiliated to them and I am only posting this thread as it has made a difference. I was on the edge of buying the new diesel in August , as they are stating it is quieter, and vibrates less. But I am now happy to keep this one as this simple fix has made it a better drive. All they do is remove the plastic wheel arch mould, stick the dynamat on the steel, replace plastic mould, you dont notice anything has been done.Originally posted by ozimacca View PostThanks for the reply, if you were able to fix it maybe Toyo ought to get off their b*ms and do the same for anyone who has the problem !
Thanks Gavin, I have saved all that just in case
Originally posted by gavinvbrf9 View PostThat is good, mine is 6 years old, so vibration can be anything, Give Simon a call at Newcastle Pro Sound in Jesmond, for $100 and $15 for seven trim clips for the wheel arch plastic (bought from toyota) you will have a quieter vehicle - their phone number is 4965 6899. They are professional installers. I am no way affiliated to them and I am only posting this thread as it has made a difference. I was on the edge of buying the new diesel in August , as they are stating it is quieter, and vibrates less. But I am now happy to keep this one as this simple fix has made it a better drive. All they do is remove the plastic wheel arch mould, stick the dynamat on the steel, replace plastic mould, you dont notice anything has been done.
