  • Originally posted by ash56 View Post
    Hiwhere did you get the brackets to fit the nudge bar to mount the lights on, or are they included in the light kit.
    Ashley
    Hi Ashley
    I just bought these brackets off ebay....they mount up pretty securely
    http://www.ebay.com.au/itm/2x-BULLBA...item3f51bc2482
    • Had my Old Man Emu 500km check and received my dual battery gear.
      Spilsy
      • Hi fellow 150's, I just fitted a 9 mode wind booster to my diesel.. what a difference!! 😃😃😃
        . Next MOD will be an exhaust the a chip!!
        • unichip has wind booster built in
          http://dynomotive.com.au/product_det..._variant_id=12
          Originally posted by GavinF View Post
          Hi fellow 150's, I just fitted a 9 mode wind booster to my diesel.. what a difference!! ������
          • Removed roof rails and installed a Rhino Pioneer platform. Not as hard a job as I thought. Took about 1.5hrs all up.
            • Ordered a TJM T3 bar for it, having given up ever seeing the AFN one in the flesh
              • Good choice!!!!
                • Installed an Icom 450 and an RFI CD933 6.5db antenna.
                  • Picked up my recovery points, air comp bracket and switches from amts. Just need time to fit them now.
                    Cheers, Nova
                      You will not be disappointed, great looking bar and even better value.
                      • Installed the GME TX3345 UHF radio in the center console with 6.6db antenna. Also moved the USB from center console to the a 3 port usb hub in the card holder and installed a UHF radio RJ45 input socket in the center console instead of the USB. Big thanks to the many guides in this forum.
                        • Built a box to contain tubs for an upcoming trip to the center. Happy with the result, however the 16mm MDF makes for a pretty heavy box, maybe 30-40kgs?
                          Anyway, I built it so I could store stuff on top of the flimsy plastic tubs (clothes and food).
                          • Hi all,
                            I bought a clean skin recently and got it back from the workshop today. I had ARB deluxe front bar with 18" great white LED light bar fitted, ARB underbody, ARB sidesteps, Safari snorkel, ARB roof rack and awning. Also got a Redarc dual battery setup so I went all out. Looking at getting OME 50mm lift and Cooper ST max wheels in the next week.
                            Can anyone tell me if I can get 285's on with a 50mm lift? I'm currently running the standard Dunlop A/T which is 275.
                            • Originally posted by Johnnymac View Post
                              Standard size is 265/65R17. 285/70R17 requires a different offset rim of about +10 to +15.
                              • Cheers for that amts. Think I'll stay the same size to what I've got now but in a better tire.
