  • Nice stats on the injectors.
    Did you clean the EGR yourself or get someone like John to do it and did you plate it?
    Graphite 2013 "Altitude" with an expanding wishlist.
    • Had someone clean it for me...
      • Took it out yesterday.
        Still running stock suspension.
        Looks like it is time to look at a lift, although we did get through everything without damage.
ID:	652825Click image for larger version
ID:	652826Click image for larger version
ID:	652827Click image for larger version
ID:	652828Click image for larger version
        Another great day out.
        A few other Non Prado's with big lift an lockers did have a little bit of trouble getting up the step in the Pic 2 - 5
        As has been mentioned on here. "You will be surprised where a stock or close to stock Prado will go"
        • Fitted an AMTS rear wheel spacer. Now have room for the 285 spare and are looking at making a rear light bracket for a 6" led light bar I have had lying around waiting for a spot to put it. Here is the wheel spacer.Click image for larger version
          • Originally posted by Fred63 View Post
            [ATTACH=CONFIG]21947[/ATTACH][ATTACH=CONFIG]21948[/ATTACH][ATTACH=CONFIG]21949[/ATTACH][ATTACH=CONFIG]21949[/ATTACH][ATTACH=CONFIG]21950[/ATTACH][ATTACH=CONFIG]21951[/ATTACH]
            Nice drivin! Thankx for the pics.
            Don't go too high with the lift & travel.
            Who mentioned that?
            • I remodelled a rim and trye. Thought they were a bit to functional.
              Sent from my SM-G900I using Tapatalk
                Looks like a fun day out Fred
                Good Driving technique can get you a lot further in most cases.
                Its generally the other brands who are surprised where a stock Prado will go
                • Originally posted by brogers View Post
                  What shocks and springs did John install for you?
                  I'll be visiting John again in the new year...he did my first Prado suspension lift...spot on!
                  I went with the Dobinsons and Bilstiens, was going with them originally, then decided I would give the Ironman Foam Cell Pros a go. Un fortuntely they didn't fit the dobinson springs and Ironan springs for the Prado were not available.
                  so, did not want to wait, so settled with the Billies......
                    Who mentioned that?
                    we know who mentioned that
                    thanks
                    not to bad for a shopping trolley
                    50mm lift maybe a touch over
                    I would like to try to keep the ride comfort and maintain the current flex.
                    by keeping the spring rate about the same as stock. suggestions?
                      yep
                      last time out on the same track Black120 was there and they were surprised how the to Prado's went.
                      All the vehicle's there yesterday had big lift.
                      I was asked twice are you sure your going up there.
                      some didn't know I had done that before.
                      best info on this forum
                      get out and us it
                      see what it will do
                      workout wants and needs. (the wife wants the catalogue thanks to the GTG)
                      Join a club
                      One bloke there moved from a Prado to a so called more capable Patrol and had to reveres back and put the lockers in to get up.
                      • Originally posted by stevep84 View Post
                        ouch.. that tyre might not buff out lol
                          Nope, it was quite deflating. 8)
                          • Originally posted by ceasar m View Post
                            Installed the EGR plate, test drive and no engine light. Seems hard to but not that bad. looking forward on my next oil change soon.
                            What hole size? Link to the ebay store?
                            • http://www.ebay.com.au/itm/EGR-Blank...item2c9e9e9176
                              with 7mm hole as ############# recommended.
                              • Mounted a rear 20w Led light and bracket to AMTS wheel spacer. Came up a treat. Sits right between spare wheel and back window. Rear wiper misses it by 5mm or so. Now I just have to wire it up when I get a chance over the holidays. Click image for larger version
ID:	652850Click image for larger version
