Coolbox problem
  • Coolbox problem
    Hi, yesterday when turned on coolbox between front seats, made a clunck noise and the blower didnt work, after hit the wall of the box with the hand it started, but now its happening everytime I turn it on, tomorrow I'll call the dealer because still under warranty, anybody had experienced problems with the coolbox?
    Sounds like the fan has given it away. They should replace under warranty.
      Is it just a fan? Or does it pipe a/c. Air through too? I have a GX and would turn mine into a cool box if it was an easy mod. The vent is already in there.
      Thanks.
        Thanks.
        Well, this has its own evaporator and piping and no air ducts from the main a/c unit,
          Probably the same as the Grande. Own evaporator which is fed off the A/C unit in the rear. I sometimes get a noisy fan which is a result of the Evaporator icing up and the fan hitting it. I turn it off for 5 min and its good for another few hours...
            Got news, they'll check it in two weeks,
              My moneys on the fan motor.
                Good news, dealer replaced blower motor, fortunately under warranty because it would cost US 475.00 + 125.00 labour,
