Stall recovery. All the text books say that you should turn the key with the clutch out for a stall recovery. How do you do this in a manual 150 Prado with the ignition inhibitor switch on the clutch?
Stall recovery
Having just been through this a month or so back with driver training in a local 4wd club, I was labelled a trouble maker for not following the procedure .
From memory and apparently this is the approved association procedure. Stall, right foot on foot brake, engage hand brake, check surroundings etc, when clear clutch in and select reverse, clutch out.
After doing this step, this is where manual 150 owners break the rules, as the engine wont start unless the clutch if fully depressed (yes you can trick the sensor, I remember reading on here about someone who did that permanently).
What the procedure became for me was, right foot is still on foot brake, release the hand brake, depress the clutch to start the engine and slowly release the clutch until you feel it starting to load up and at that point, fully release both clutch and foot brake at the same time. Once this had been done a couple of times, it did felt like to a proper stall start.
Hope this makes sense and helps or at least adds to the discussion.[B]Dave[/B] - 2010 Silver GXL Prado 150 TD Manual.
Good work DGW. Unfortunately if you are on the limits of traction, pushing the clutch in would have you sliding backwards out of control. Sounds like you need a switch to bypass the sensor or as suggested permanently bypass the sensor. And I thought autos were hard work on steep slopes.Prado Polar White 150 GX 3.0 TD Auto. HR TB, ARB delux bar, Hella R2000 lights, Magnum winch, ARB 50mm lift, BFG AT 265/70R17 on 71/2" alloys, Alloy side steps, Rhino sport bars, Tint, UHF, Scangauge, Aux batt (ABR kit), Cargo barrier, 50l water tank, Storage system, Elec brake con. ARB compressor
You forgot the bit about shifting into low range for a proper stall recovery. A lot of the training centres around old-school manual vehicles. They haven't kept up with the technology and autos. Even Rodeos and Colorados need the clutch in so the electronic transfer will operate. Much of the gizmos for keeping you safe on the sealed roads creates issues when venturing out into the rough. If you have hill descent then you probably wouldn't need to do the reverse stall recovery technique. And prior to backing out, the book also lets you consider shifting to low range and continuing in upwards on your journey if that is practical.Dave
Hi Barajack, whether you have a modern manual or not, the clutch still has to be depressed to get reverse. If holding your foot on the foot brake, while selecting reverse, is not going to stop you sliding backwards, you would have been sliding back down a long time before then.....[B]Dave[/B] - 2010 Silver GXL Prado 150 TD Manual.
Hi Bushbasher, point taken about low range. I made an assumption (which is never good) that the entire process was being done on low range. Also so agree the training courses are very out dated compared to the new technology available in new vehicles but still very worthwhile.[B]Dave[/B] - 2010 Silver GXL Prado 150 TD Manual.
Originally posted by DGW View PostHi Barajack, whether you have a modern manual or not, the clutch still has to be depressed to get reverse. If holding your foot on the foot brake, while selecting reverse, is not going to stop you sliding backwards, you would have been sliding back down a long time before then.....
Doing it properly, you have gently released the foot brake before you crank it, clutch already out.
Originally posted by DGW View PostHi Barajack, whether you have a modern manual or not, the clutch still has to be depressed to get reverse. If holding your foot on the foot brake, while selecting reverse, is not going to stop you sliding backwards, you would have been sliding back down a long time before then.....Prado Polar White 150 GX 3.0 TD Auto. HR TB, ARB delux bar, Hella R2000 lights, Magnum winch, ARB 50mm lift, BFG AT 265/70R17 on 71/2" alloys, Alloy side steps, Rhino sport bars, Tint, UHF, Scangauge, Aux batt (ABR kit), Cargo barrier, 50l water tank, Storage system, Elec brake con. ARB compressor
Hi Barajack,
After owning manual 4wd's for around 28 years, changing the process for a stall start in the 150 has been interesting to say the least. I haven't had to do this under any great pressure but having practiced this process a few times over the last couple of years, I know I will remember it when I curse that switch on the clutch pedal
I will be really interested to hear your thoughts on it, as it does feel very different to what I have always done. Also, the more you can load the clutch against the brake before letting both the clutch and brake off together, the better it works.[B]Dave[/B] - 2010 Silver GXL Prado 150 TD Manual.
You blokes with your fancy 150s and all the electronic wizardry should be able to slide backwards in angel gear, rip on the handbrake, pull a 180, drop the clutch and ease down the hill effortlessly. Something for us mere 120 owners to marvel at and take photos of.Dave
I will be really interested to hear your thoughts on it, as it does feel very different to what I have always done. Also, the more you can load the clutch against the brake before letting both the clutch and brake off together, the better it works.Prado Polar White 150 GX 3.0 TD Auto. HR TB, ARB delux bar, Hella R2000 lights, Magnum winch, ARB 50mm lift, BFG AT 265/70R17 on 71/2" alloys, Alloy side steps, Rhino sport bars, Tint, UHF, Scangauge, Aux batt (ABR kit), Cargo barrier, 50l water tank, Storage system, Elec brake con. ARB compressor
