Originally posted by reggie426
View Post
NEW PRADO coming? Next year? 2015?
Any idea where that engine is coming from? Not another start to the D4D life cycle.
Just read a FB post from Berrima Diesel with many customer still complaining about the injector issues. Is that a thing of the past or do the current models also have the same issue? I did read here on PP that it had been fixed or people hope that it had been fixed. Are there any indicators to say it has been fixed or is still an ongoing issue?
I see many happy owners and some people with bad stories. What is the differentiator between those?
CheersD4D. How long will it last?
Injectors are, and always have been, a wear and tear component, or a consumable. They always have needed to be replaced when they are worn. The problem with the modern Toyota diesels is when they are worn they over fuel to the point they can damage engine internals. Many people also feel the life span of these injectors is too short, and they should last longer than they do. The problem is compounded by dealers not doing the appropriate checks when servicing and not making the customer aware of the "issue".
There was an earlier issue where the injector seats (or "sheets") allowed combustion gases into the oil ways, this caused carbon build up in the oil system, eventually blocking the oil pick up and causing oil starvation. This issue has been solved with new revised injector seats, although it was not done through any recall or customer satisfaction program, but was done at the customers expense when either the valve clearances were checked, the carbon deposits were noted, or the engine suffered oil starvation. Most 150's will have the new style seats, you would have to be very unlucky to get one of the early ones with the old seats.[LEFT]Silver 150 Facelift
I would say no as its only another 18 months away for a new model, give or takeOriginally posted by wanted View PostAny further mid/end of life upgrades for 150 before they hit the run out stage?2011 Upgrade V6 GXL Graphite, Optima Yellowtop/Redarc Dual Battery setup, Dobinsons/Bilsteins 2inch Lift, Rhino Pioneer SXB Tray, Foxwing Awning/Tagalong
The 120 major update was in 2006 so about 3 years before replacement. If the timing above is correct then the facelift will be the last major change in a 6 year life cycle.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
3k rise with increasing sales pressure! Although some other companies have had small price increases that they have offset by special offers for year end. Not sure how long it will last?Originally posted by Piney View PostInfo received yesterday from a Toyota dealer indicates there is no new model planned to be released in 2015 because the facelift model is less than a year old. From another Toyota dealer, he states pricing restructures will see the 2015 built Prados increase by approx $3000.D4D. How long will it last?
Q1 2016 with reveal in Tokyo Motorshow November.Originally posted by Piney View PostAgreed. New Hilux will be released???
Sent from my iPad using Tapatalk[CENTER][B]-=2014 GXL D4D Auto Graphite, Firestone Airbags, ARB/Optima D34 Dual Battery, ARB UVP, TJM Airtech Snorkel[/B][B]=-[/B]
[/CENTER]
