An alternative to a ScanGauge
  • An alternative to a ScanGauge
    My son showed me an OBD2 II Bluetooth Car Auto Diagnostic Interface Scanner Tool that could be a much cheaper alternative for a Scan Gauge and seems to offer the same sort of info.
    He has one fitted to his SS Commodore and the information below is transmitted and available to read on his mobile phone.
    Clear trouble codes and turn off the MIL ("Check Engine" light).
    Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
    Display current sensor data, including Engine RPM, Calculated Load Value, Coolant Temperature, Fuel System Status, Vehicle Speed, Short Term Fuel Trim, Long Term Fuel Trim, Intake Manifold Pressure, Timing Advance, Intake Air Temperature, Air Flow Rate, Absolute Throttle Position, Oxygen sensor voltages/associated short term fuel trims, Fuel System status, Fuel Pressure.
    There is a number of these Diagnostic Interface Scanner Tools on Ebay ranging from a few bucks with free postage to others more expensive.
    Set your phone up in a cradle and scroll through the menus but, before getting one check, as some listed will not work on a 'I' phone.
    Has anyone out there in Prado Land got one installed and importantly ..... does it work and what are the pitfalls if any?
    Cheers Graeme
    G.Johnno
    Lurker
    I have a customer who uses a $30 obd2 Bluetooth or it might be wifi, not sure. Some app pretty cheap, much cooler than a bodgy looking scan gauge Velcro to ya dash. Plenty info available on it, you can choose what funky screen & what info you want up. Different apps to choose also.
      Also interested in a response to this, especially regarding injector feedback values, map, egr values etc
      thanks jika
      09/08 Prado GX D4D White, Auto, Option Pack 1, Soveriegn Bull Bar, 2" Ironman lift, Ironman snorkel, catch can gone EGR blank with 6mm hole installed
        I read somewhere ( maybe on here) about the Bluetooth ones overheating and melting from long periods of use. None of the Bluetooth/app combos I found had all the guages I wanted. Specifically the Auto Trans Temp codes, which what I'm really interested in as an auto owner. I'm not sure if the apps have fuel usage as well. Which I've found useful.
          The OBD2 II Bluetooth Car Auto Diagnostic Interface Scanner Tool, does not work with Toyota. Toyota has a different system. I bought one from e-bay ,works good on most cars but it doesn't like my Prado.
            My Prado isn't obd2 so I can't get a scan gauge. I've been looking into these things as well but I guess that's a no go too
            Blake
              I had my $30 one plugged in and the car wouldn't start. That was enough for me to chuck it in the bin.
              2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
              2008 Jayco Dove Outback - "Davo"
