Transmission Temp PID - Android
  • Transmission Temp PID - Android
    Not sure if this is the right spot so Mods feel free to move.
    After a lot of searching I finally came across a PID that works for the 150 Auto temp courtesy of a mate of mine with a 200. Seems it works on both.
    I use the Torque Pro app on my ASUS tablet and added it as a custom PID
    PID :- 21D9
    Long name :- transmission temperature (or whatever you want)
    Short name :- Trans Temp (again whatever you want)
    degrees :- C
    range :- max 180
    There is another line there I think you leave as :- 1
    Formula :- ((((((E*256)+F)*(7/100))-400)/10)-32)*(5/9)
    NOTE: There are 6 open brackets at the start
    OBD Header :- 7E1
    Not sure of the order of the names range etc but as I am sending from my tablet I don't want to lose this by calling up the app
    Anyway good luck
    Geoff
    Blue Storm 150 D4D GXL, Toyota Tow Bar, Cheepo floor mats, Tough Dog Springs & Shocks, Colour Coded TJM T13 steel bar, KingOne winch with rope, GME 3440 80 channel uhf. Not allowed to make hole for snorkel - yet..
    This works with Torque Pro on my 2012 Prado 150:
    Long Name: Transmission Temperature Pan
    Short Name: TFT Pan
    PID: 2182
    OBD Header: [leave blank]
    Formula: ((((A*256)+B)*0.35-3600)/90)
    Long Name: Transmission Temperature Torque Converter
    Short Name: TFT Conv
    PID: 2182
    Formula: ((((C*256)+D)*0.35-3600)/90)
    I have so far not found a good way of verifying that the values are actually from the correct sensors.
    It seems the TFT temperature lags the engine coolant temperature by a few degrees.
    In park or neutral, the TC temp is only about 1°C above the pan temp.
    In drive, with the car stationary and idling, the TC temp goes up quickly and eventually is about 10°C above the pan temp.
    I'd like to get a bit more info from the transmission, e.g. which gear it is in (can't always tell when its in 'drive').
    Does anyone have more info on Toyota PIDs?
