Cleaning Headlight Cover
Hey fido,
I searched but I used cleaning not polishing :-)
Thanks for that.
Admin, kill this threadGeoff
Originally posted by Geoffury View PostMy 2012 Prado headlight factory cover is suffering from sun fade across the top of it.
[ATTACH=CONFIG]19531[/ATTACH]
[ATTACH=CONFIG]19532[/ATTACH]
There are a few repair kits on the market, has anyone tried any?
Do any of them actually work?2010 Toyota Prado GXL V6 4.0i - Silver Pearl - ARB Deluxe Bar - Warn Magnum Winch - GME UHF - Dual Battery - Redarc 1225 - Cooper AT3's
[url=http://www.TickerFactory.com/]
[img]http://tickers.TickerFactory.com/ezt/d/4;10752;127/st/20140913/e/Riff+to+Tip+2014/dt/14/k/f753/event.png[/img]
[/url]
Originally posted by Geoffury View PostSaw that Supercheap had 20% off today so went and purchased some Meguiar's Headlight Lens Correction
[ATTACH=CONFIG]19563[/ATTACH]
Will see how it goes tomorrow and report back2010 Toyota Prado GXL V6 4.0i - Silver Pearl - ARB Deluxe Bar - Warn Magnum Winch - GME UHF - Dual Battery - Redarc 1225 - Cooper AT3's
[/url]
I've used Brasso in the past as the head lights were heavily mud stained-work ute.Fitted so far:-Toyota Alloy bar,Redarc BDCD1220 battery managment system and dual power outlet,tracklander full length rack and ladder,Milford cargo barrier,Kaon transmission guard, UVP& Lower Shock mount Guards,Dobinson/Bilstein suspension,Toyota Bonnet and headlight guards,39ltr engel and an opposite lock stubby holder (from the old '80' series),Polyair Airbags,Pradopoint sticker,Gonefishin' custom Sidesteps.
Will see how it goes tomorrow and report backAug 14 150 GXL D4D Auto. BFG KO2's. Hi flow muffler. 7mm EGR restrictor plate.Bushman fridge.
So I used the Meguiar's product today on both my Prado and the wife's Suzuki.
This is what you get in the kit
I wet the sandpaper pads in some water, and cleaned the headlight cover of the usual dirt.
Then used the 4 sandpaper pads, (the 3rd & 4th fine cut are on the one pad, different each side)
Starting with no. 1 - coarse, working the headlight cover left and right and then up and down.
After 2 mins going each way, the sun fading was gone, but there was the scratches from the sand paper.
Then I used pads 2, 3 & 4
By the finish of no. 4, the scratches were almost gone.
From there I used the Plastx which is a fine cutting liquid, with the Orange microfibre cloth.
Rubbing in circular patterns, I worked the plastic and removed all the scratches,
it was back to like when I drove it out of the dealership.
It took around 20 mins per headlight to get to this point.
From there I used the Headlight Protectant paste.
I wiped this over the entire lens, it left I light smear, which was then wiped off with a terry towel clothe.
The lens comes up looking this.
All in all happy with the result.
They have come up nice and clean, and now have a new UV protectant coating.
In future, I would just purchase seperate bottles of the Plastx and the UV Protectant.
They were on the shelf next to this product, for $20 per bottle, 200ml I think.
I say this, as I then went to work on the wife's Suzuki, but didn't use the sandpaper pads.
I just started with the cutting liquid. The lens on her car were much worse than the Prado,
And was starting to turning yellow.
The lens on the Suzuki came up just as good as the Prados.
Took the Suzuki for a drive tonight and took notice the light was clearer.
I will be purchasing the UV Protectant and reapplying it each 6 months or so.
I'm in no way associated with this product or paid for this review.Geoff
I just used a light cut and polish compound and it worked a treat on my 150 series. In fact when I looked at buying a dedicated product from Repco the guy suggested I just use cut & polish, does the same job for half the cost![B]2010 GXL Prado D4D Auto[/B] - ARB Deluxe winch bar, Roadsafe recovery points, Rhinorack Pioneer platform, AMTS fuel filter/compressor combo bracket with FM100 filter and ARB compressor, Maxtrax, TIN175 transmission oil cooler bracket and tranny cooler. I'm sure I'll find something else....
