heated front window problem
  • heated front window problem
    Hi All, put the heater on to demist and could I get the @&%!in off ??? pressed every button there and nothing is there a secret code or something that has to follow a set procedure ???
    Atheism is a non-prophet organization.
    Haha yes it's very frustrating when you don't know how. I was in the same boat until I figured it out. Lot of expletives being thrown around!!
    You gotta press the button that cycles it from face/feet/demist. Until you do that, the thing just keeps blasting away!!
    Hope this is what you meant...
      Course I knew that !!!!!!!! talk about user friendly LOL yes also tumbled you have to hold the off button " to get out of rear A/C and of course "I knew that"
      big thank you for that one buddy................
        Demister in Perth? I would have thought your biggest problem would have been that the demist button doesn't work from lack of use......
          Yes me too and BTW the 150 fogs up really bad my 90 series didn't but this one does.................?
            That's odd. Wonder if its different grade/quality/brand of glass - if that would even make a difference?
              No idea but when its wet you have to put front demister on or it just gets worse, not even opening the window helps.................
