12 volt not working - where is the fuse?
  • 12 volt not working - where is the fuse?
    Hi, I plugged in a 12 volt blower to pump up a water ski doughnut and I think it was faulty and blew my 12 volt power to both sockets (front console and back seat). I went to check the fuse in the main box under the bonnet and stuffed if I can decipher the legend on the inside of the lid and locate the fuse for the 12 volt power.
    Firstly, am I looking the correct place - is this the only fusebox?
    Secondly, if I am in the right fusebox, what label is on the 12 volt fuse?
    There is a 15A fuse for those 12v outlets, it is labeled P/outlet and is located in the fuse panel in the underside of the console above accelerator pedal. And not really easy to get to!
    Prone
    2018 Prado 150 VX Auto
      There is a second fuse panel under the driver's side dash. I'm not sure which box the fuse will be in but if you have the manual it should tell you in there.
        Prone
        Thanks for that. Will give it a crack this evening
          After putting my neck out trying to get my head upside down into the footwell to look up under the dash I found the fuse box sitting up behind the wiring and other stuff (why the hell did they make it so hard to find and access??) and managed to locate the P/outlet fuse and replaced it by feel as I couldn't get in a position where I could see and get my hand in there at the same time. It did the trick so all now working.
          Thanks again for your advice
          BSD
