Trim Removal
  • Trim Removal
    Hi I have seen a thread re removal of the rear trim for a gxl and a mention for a gxl having an extra bolt but does anyone have a diagram for the side were you would run extra cable as that is what I am attempting
    Not sure but I hear you can get a useful hand in behind the trim by removing the rear cup holders.
      Many thanks I will try that
Name:	150 rear panel.jpg
          Nice one Mozz ! Where did you get that ?
          I've removed it myself several times but always worried i'm going to break a clip by not pulling in the right place.
            Thanks Mozz and Maulbeagle that is my concern using force will break the panel.
            I will give it a go and report back.
            I assume the diagram is for a gxl and the gx is slightly different but should be attached in a similar way but may have an additional bolt.
              From experience, it's highly unlikely you could break the panel, but more likely you could break one of the clips holding it in place. These are available as spares though so can be easily replaced.
                That come from the Toyota workshop manual.
                  Mozz is that the workshop manual for facelift 150s or the older ones ?
                    Many thanks managed to get panel off install and put all back only bent one clip ie plastic fatigue otherwise all good
