Originally posted by Nik83
View Post
Advice Pls! N00b switched into 4Lo when in Park, then into Drive. - Result - nasty grinding.
DAC wasn't engaged, but i tell you what, i've had the ABS kick in when pulling up in a little skid on dirt, and christ that's a bit more unpleasant than when i've noticed ABS kick in on other cars. I'll have to test the ABS and the DAC out a bit more so i know better what to expect and so i know they're working properly if they are this unpleasant when they're doing their job. Thanks again for the tips :-)
A few weeks ago had mine go off similar to how the DAC goes off but not as aggressive.Originally posted by MrBloop View PostDAC wasn't engaged, but i tell you what, i've had the ABS kick in when pulling up in a little skid on dirt, and christ that's a bit more unpleasant than when i've noticed ABS kick in on other cars. I'll have to test the ABS and the DAC out a bit more so i know better what to expect and so i know they're working properly if they are this unpleasant when they're doing their job. Thanks again for the tips
Selected 4LO only
selected S1
Steepish clay hill
foot off the brake
once it started to slip on the hill it sounded like ABS / mild DAC sound for about 2-3 sec then settled it's self down.
But it was a very slippery hill
