fuel tank Bash plate on 2010 D4D
  • fuel tank Bash plate on 2010 D4D
    Hi,
    seeking advice.....is it easy to replace the bash plate on the main fuel tank (one from drivers side to the rear passenger side), or do I need to purchase a new tank.
    Regards SAFTGT
    2010 Prado GXL, Engel 40L drop slide, Dual battery, ARB CKMA12 Compressor, Micky Thompson.
    Yes, you can replace the bashplate. What happened?
      Thanks for the response AMTS. The current plate is badly dented as a result of been drag in a number of recoveries. I was not sure if it is a bolt on/bolt off for an after market or OEM replacement........plus I need to start saving for a lift to prevent it from happening.
      Regards SAFTGT
        Take it off and do some home panel beating with a big hammer. Free!
          That is what I will doing .....Free is the best....keeps the handbrake happy....thanks for the advice
          Regards SAFTGT
            Hi, has anyone looked at the below skid plate
            http://www.asfir.com/toyota-land%20cruiser%20150/534170
            Regards SAFTGT
              Been there, done that ..... numerous times. It is pretty quick and painless to remove and replace.
              Ironman actually sell a heavy duty plate for the front tank that bolts up to factory fixing points.
