Cabin Fan - Squeaking/Squealing Noise
  • Cabin Fan - Squeaking/Squealing Noise
    Hi all,
    My 2010 GX is emitting a quiet, but annoying rhythmic squealing noise when turned on. It speeds up when ready the fan speed and slows to a stop when I turn it off, so I am suspecting some component of the fan setup itself. My initial thought would have been a leaf, but the noise is over 2 years old and that likely would have stopped/broken down by now.
    Has anyone experienced this noise or something similar? How would I access the fan to check/tighten it? Any other thoughts?
    Thanks!
    2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
    2008 Jayco Dove Outback - "Davo"
    Funny, my 2010GX had the same issue. Like you I thought it was a leaf or something caught in the blades and it was quite annoying.
    I pulled the fan assembly out (3 screws from memory) and cleaned it but that made no real difference.
    Even considered spending 200 bucks on a new fan assembly but I eventually traded the car in on a 2014 GXL, which incidentally still has the same noise on low speed, although not as loud as on the last car.
      I also have the same issue with my 2011 TX.L.
      Its annoying while driving and replacement is expensive (Eqv. around 270AUD)
        I’ve just gotten used to mine (almost 8 yrs old now). Or maybe the other creaks and rattles have just gotten louder ;-)
          My GX does the same. First there was a soft clicking noise kind of like when you put a playing card in your bicycle spokes which did end up being a leaf, but just recently started making the squealing noise. Haven't got round to pulling it apart to find a solution but will post a response if I do.
