3L to 2.8L conversion?
  • 3L to 2.8L conversion?
    Hi all
    Has anyone ever replaced a 3L with a 2.8L in the 150?
    im in 2 minds on a rebuild or a 2nd hand 3L.. and then a cheap 2.8 became available so have to ask?
    is it possible?
    if you could get the car as the donor and swap all the wiring, dash & computer
    there is a cheap 2.8L on gumtree
      it would be a fair project , and doable mechanically , you would also need the instrument panel from the wreck. The only big problem i can see is bypassing the immobiliser if it didnt come with the donor engine and wiring harness. Maybe if a tuner can remove the immobiliser map from the ECU then problem solved.
