No central locking, fuel gauge reading or Stereo
  • No central locking, fuel gauge reading or Stereo
    Hi,
    Sadly I’ve had to have the motor on my 2014 facelift 150 replaced.
    It is already to be picked up, but the mechanic reports that as above, Central locking is not working, the fuel gauge reads empty and displays the yellow icon on the dash and there is absolutely no display on the stereo unit.
    Car will start perfectly with the fob touching the start button only.
    The mechanics are thinking electrical and a blown fuse on that circuit? The batteries in the Prado have been disconnected for a lengthy period.
    I’m thinking more like a communication loss between the fob/ key and the security, or that the key needs to be paired again to the security ecu.
    Does anyone know of this issue or how to get the key to pair either manually or by Techstream?
    If the car starts with the fob touching the start button, then try changing the battery in the fob.
    As for all the other stuff not working, Id be checking the fuses to see if anything has blown.
      They tell me that they have checked all the fuses.
      Can an anyone suggest which circuit would control all of these symptoms? Under bonnet or rhs inside the car to help get this sorted?
        Hooray. Problem located. A very contrite mechanic has found that the engine looms were inadvertently transposed. All sorted. Thanks.
          transposed ????
          want to explain a bit more?
