Removing centre console for cool box fan replacement
  • Removing centre console for cool box fan replacement
    Hi Guys,
    I am trying to find a step by step procedure to remove the centre console to access the cool box fan in a 2012 Kakadu. It needs replacement and the local Toyota shop is asking few thousand dollars (with a weeks labour) as it is a big job.I do not think they are advising correctly, more like we dont want to do it. Any advice/steps is appreciated.
    Cheers.
    There is a thread somewhere on this forum that discusses centre console removal. I removed mine some time ago & made step by step instructions on how I did it. Use the link if you want a copy of my file (too large to add here) otherwise there are instructions in another thread. Hope this helps.
    [COLOR=#b22222]Prado 150 2.8 GX Auto - ARB Bull Bar, Towbar, Dual Batteries, UHF, 2" lift with King Springs & Bilsteins[/COLOR]
      Link didn't copy properly, try using this: https://www.dropbox.com/sh/ntuqfz6xa...pdqiCgf8a?dl=0
        Its not a hard job, take both seats out and strip console, around 1 hour to get it stripped down. Before replacing anything I would be checking its not just a fuse. There is a hidden fuse under the console near the cooler fan unit itself. Last one i looked at it was this fuse. Total job start to finish 2.5 hours including cleaning everything under the seats.
          Thanks alot Geo. gonna attempt this! Do you need to take out the seats??
            No, I didn't remove the seats.
