Apple CarPlay
  • Apple CarPlay
    Hi All,
    I saw an ad that the current (2020) model Prado has Apple CarPlay.
    Does anyone know if Toyota can upgrade the software in my 2018 VX Prado to add Apple CarPlay?
    2009 Prado 120 D4D, Silver, ARB Deluxe Winch Bar, IPFXS, Safari snorkel, diff breathers, OME, GME UHF, Warn Winch, ARB portable compressor, OEM Towbar, Tekonsha brake controller, tinted windows
    No you cannot.
    Though you can buy modules that allow you to do so.
    https://m.aliexpress.com/item/4001240310971.html
    I am currently considering this for my 2019 GXL, another forum user has fitted it and reports that it works really well.
      I have this one in my 2019 GXL,
      https://www.ecvisionsound.com/collec...31852661702759
      It works well, does everything I expected, fantastic for dialing, calling from contacts, finding locations on the move.
      Android Auto voice control is brilliant compared to the Toyota one, first go everytime.
      The only issue I have is that I don't know how to use FM radio and voice direction from the system, I can only have one or the other.
      Either,
      1/ internet radio and voice from system for GPS, messages etc. I have to select AUX to achieve this
      or
      2/ FM/AM and no system voice, voice control works, the system hears me I just have no system voice talking to me so I have to watch the screen for directions
      Not ideal and there's probably a work around, I just haven't found it.
ID:	754882Click image for larger version
ID:	754883Click image for larger version
ID:	754884Click image for larger version
        Duplicate post,
        I apologise for all the duplicates, when I tried to post it came up as an error, so I removed a photo each time and tried to repost thinking it was a size issue but it actually was posting.
        Mods,
        can the duplicates be deleted?
          Duplicate post
            Duplicate post
              Duplicate post
                Not available from Toyota yet, but you can install aftermarket plug and play ones.
                  Either,
                  or
                  Hey mate,
                  I've got the same exact module and I can confirm that there is no work around. The module is using the Aux input for all sound. So as soon as you move off that, you won't receive any sound from the Aux input. As you correctly note, the system will still be able to here you though.
                  Personally, I hate spoken navigation directions as they constantly cut through the podcasts that I listen to. I'm happy to have the navigation on screen only. I use internet radio most time but occasionally I'll switch the Prado factory unit to AM/FM if the phone is playing up.
                  It's definitely not a perfect solution but very, very good for what it is. I believe the current models that come with Carplay are wired only. Wireless Carplay isn't available yet. So the unit from EC Vision is definitely a step up on that front. Hopefully the Prados in a few years will have the wireless Carplay option as standard. I've also installed wireless charging coils in the tray under the AC so I'm completely wire-free.
                    Hi Cortez,
                    Thanks for your note and clarification re the no work around, I actually pretty much use it as you do which is why I've not bothered looking much further into it.
                    I agree, very good for what it is, a lot more user friendly than the original.
                    Looks like this is it at a better price too,
                    https://www.aliexpress.com/item/4001240310971.html
                    I'm interested in your wireless charging as the USB connection doesn't supply much.
                    Do you have any info? photos?
                    Thanks,
                      Hi Cortez,
                      Thanks,
                      Hey mate,
                      See this thread for details.
                      https://www.pradopoint.com.au/forum/...e-charging-mod
                      I've done this mod to each of the 2 Prados I've had and it works a treat. I'd recommend getting a triple coil charger as it gives you a larger surface area for charging. I contemplated putting 2 triple coils side-by-side in the console but couldn't be bothered. Plus my wife and I both have the iPhone 12 so they wouldn't fit side by side in the console anyway.
                        Can you identify who? I am interested but would like to talk to them about it some more.
                          This is the post link https://www.pradopoint.com.au/forum/...on-2018-kakadu
                          The forum member username is ducksnuts.
                            I've fitted this to my 2019 Prado VX. Very easy to install. It works quite well. Only the audio sound isn't as good as the factory system. i.e. it looses some quality as it is processed through he CarPlay unit. I also experience the screen locking up on occasions. i.e. the touch screen become unresponsive. It means having to reboot the whole system. Which luckily can be done by holding the on/off button down till the system reboots and the Toyota logo shows on the screen. Would have been a showstopper if I had to pull over and turn the car off and back on.
                            With regards to the audio. I have found using some apps the sound is like out of a tiny speaker and with lots of treble. Also the Volume know does not work when using CarPlay system, you have to use the steering volume buttons. Additionally the phone handfree does not use the factory system and definitely sounds worse to the far end caller as the microphone provided does not work anywhere as well as the Toyota factory mic.
                            I have used the interface on and off, but have reverted to the Toyota main system for most of my driving. I still prefer apple maps / google maps but the other issue just don't make this as integrated as I would like.
                              I am also looking into this, but don't want to change the factory unit. I saw on Toyota site (local dealer) they advertise an upgrade...not sure if complete new unit or just some or other conversion...sent and email and waiting for response. I also came across this one and it looks great....anyone tried or did this one?
