Any suggestions on where I could permanently mount a a 1500w inverter & still use the 7 seats in the 150? Thanks in advance, sorry if already discussed!
Inverter positions??
A 1500W inverter is going to draw over 120Amps at 12v at full load IF it is 100% efficient, which it won't be. Assuming an efficiency of 90%, it will be drawing 140Amps from the battery.
So 1) You will need very thick cables (4 AWG) 2) the inverter will need to be mounted in the engine bay, to keep the cables short and 3) Your battery will only last a few minutes at that current draw.
