Kakadu leather seats install in gxl 150 electrical problems
  • Kakadu leather seats install in gxl 150 electrical problems
    Hi
    Am trying to install a 2010 Kakadu 150 leather interior 7 seats installed in 2013 gxl 150
    all are in accept the rear Dickie seats because they are powered .
    and the front passenger has 3 looms to plug in but no power .
    and drivers has power in the forward and reverse motion and the back seat tilt and lumbar but the motor that raises the seat up has no power ?
    any help or anyone else’s experience on this would be greatly helpful and appreciated.
    regards
    mark
    Hi did you manage to sort anything out yet
      Gday
      no just got back from auto electrical and said they cannot do it
      Toyota state that the wiring harness for the seats is 3.5k and then some other part in engine which is another 2 .5 k
      I just need power to the seats ?
      the rear sickie seats need power and a switch to move them up and down ..etc
      dont know what to do now ?
      confused frustrated
      cheers
      mark
        thanks for getting back, ill most likely update you as to how i get on, ive got smashed donar car so hopefully i can pull parts off
          Thanks for getting back to me, yes in order to install the rear dickie seats they need power and there is switch for them as well so after the wiring loom and wires if available . Also for 2 front seats? Where is your location ? Regards Mark
            Appoligies for getting back this late. Had the car at sparkys and they couldn't do it.even after supplying part loom switches etc.i might just try and wire some relay switches etc to directly to the 2 motors which is for base and back unless you have any developements
              All those motors will need is power from the battery. I guess it’s an unusual request for an auto electrician to do. Should just email a few different auto electricians & ask the question of what you’d like them to do. They should be able to make up a loom where the main power cable to them is split up into different plugs for each of the existing Toyota plugs. They can earth them on the steel floor under the carpet or at the bottom of the side pillars behind the plastic covers unless they use twin core from the battery/alternator. Local earthing is always better though. For all seats would be a decent job for them & fairly expensive I’d imagine.
                after sparky mucked me around i decided to put relays in to power up the motors it just means i have to use 2 buttons to do the functions,can put up pics if people wants
                  Hello Pradofacelift.
                  I‘m from Panama and recently got my 2022 Prado TXL 2.8 Diesel with cloth manual with electric lumbar support seats. Im planning to swap the seats for the leather automatic ones.
                  Can you tell if its just plug and play or what need to do for the swap.
