Suspension lift
  • Suspension lift
    I upgraded with ironman nitrogass suspension coils and tubes! It is firmer steadier but hard on bumbs!! Because of the lift 5 cm it doesn’t look
    pretty! And more noise on high spead. Do you have any suggestions how to diminish this( change of tire size..?? Or use the factory spring with the new tube and loose the lift?) thanks
    My tires are 265/60/18
      Are you sure that it is only 50mm lift?
        Wrong springs... Surely
              I think they are for a heavier Long Wheel Base Vehicle
                They are 50-100kg constant load front springs and 200-400kg rear, I put the 50-100 kg load springs in the front and rear and it rides really nicely. Yours sit extremely high at the front.
                  If this is correct, Thankats would have virtually no down travel which explains the rough ride. The springs needs to be replaced, Thankats. And the appropriate springs fitted to suit your Prado.
