Hey Folks,
After a few premature auxiliary battery failures, I'm looking for ways to improve airflow / cooling around my aux battery.
From factory, there's basically done. I tried to take a few pictures but it's so dense in there to be useless. The problem basically though is this...
After the external grill on the front, there are 2 side channels ( the red lines in the picture) which force all airflow to the radiator.The air whch makes it into the bay then is obviously hot, and doesn't provide any cooling for surrounding structures.
The red barriers are also metal, which doesn't make modification easy.
The best thing I can think of so far is something like this...
Mount some roughly 40mm flexible tubing in the bullbar gap here - possibly with a scoop for a bit of ram air effect, and run the tubing under and up past the light, to then be pointing at the battery.
(Red is the tubing, yellow battery behind the light)
Hope that makes sense?
Questions...
1) Anyone done something similar?
2) How effectifve was it?
3) How effective do we think this volume of air will be, as a general thought? Could comfortable do 2 tubes, I think, one for each side of the battery.
4) Any better ideas?
Thanks in advance all.
