Hi, I have a 150 series 2015 3lt with the original touchscreen. When I try to select a button function, the option directly above is activated. Is there any way the screen can be re-aligned/ re-calibrated . DB
Touchscreen Misaligned
I am still unable to find a solution to the realigning of the touchscreen on this model vehicle. It appears that the buttons on the bottom line a
have no sensitivity at all. What does activate though is the button directly above. For example, I have a USB connection for music from the centre console, I want to change albums, so I tap screen and get a page that has BROWSE at the bottom left and directly above it is SETTINGS. I cannot activate Browse button. Only Settings button lights and activates. No amount of trying to reach below the molding to get lower has any effect.
Does anyone have a genuine solution for this one. ?
This is instructions for a Camry touch screen of same year. Might work.
"Turn engine on...press power button on twice on the car. When the screen display turns on, press and hold power/volume button for about 12 seconds. Screen will go on and of the display. That's it. This one solved the calibration issue on my screen where I have to press 1 inch to the right of the actual button."
