You learn something new every day!
  • You learn something new every day!
    Just learnt two new things about the Prado today.
    1. After reading the latest 4X4 Australia magazine (what a great writeup the Prado gets), I learnt that you can engage low range without the centre diff lock engaged. I just presumed it would automatically engage the centre diff lock when low range was selected (as my old Pajero did). This is great for when retrieving a boat from a steep ramp or manoeuvring a trailer up a steep driveway without having to worry about transmission wind up.
    2. You can turn both TRC (Traction Control) and VCS (Vehicle Stability Control) off. I only thought you could turn the TRC off. If you press the button (left hand side of steering wheel) once quickly, it turns off TRC, but, if you press and hold it for 3 seconds, it turns TRC and VSC off. Perfect for sand driving!
    Most of you probably already know these things but I thought maybe someone didn't. It is a very well thought out 4wd system on the Prados!
    Cheers, Sam.
    Re: You learn something new every day!
    Cheers, Sam.
    1. Yup I do this to get the Goldstream up the driveway
    2. I wonder if this works for 120s, will give it a try
      Cheers, Sam.
      D4D, you have a 120 series, how do you engage low range without the centre diff locked?
        Drop the transfer case lever into low range without pressing the centre diff lock button
        I don't have a TRC button just a DAC button so '2' won't work
          Ah i see! i dont have a centre diff lock button or DAC for that matter, is your a VX or a Grande or just an optioned up GXL, i cant find an actual model in your build thread.
            GXL auto with Option Pack 1
              Yes true, and the best thing is, this also works in Hi and low gear. So I can use it to have some fun in the snow (and we will have snow in germany!).
              Cheers Pete
                there you go, the thread title is true, you do learn something everyday!!!
                  Sorry Sam to drag your post a bit off topic....
                  Can you post a pic of your gear lever area? I'm curious as I thought the transfer case lever would have been the same for all GXLs, but it appears that yours has the system on the Grande. What exactly do you get with Option Pack 1?
                    OP 1 on a 120 GXL gave you
                    Traction Control
                    Stability Control
                    Downhill Ascent Control (DAC ) - there's a seperate button for that
                    Side and Curtain Airbags
                    It virtually makes it a VX without the leather.
                    However if you don't have it, you can't get it - it is a factory only option.
                    All became standard on the 150 of course.
                    Cheers, Wayne
                      So does D4D's transfer case lever have H, N, L on it?
                        120 or 150 ?
                        120 auto does, plus a CDL button and if you have OP1, a DAC button, that's all.
                        But since this is a 150 thread, getting off track.
                        Cheers, Wayne
                          Have a look at his build thread, there a is a photo there that shows it quite clearly, first page i think.
                              2. You can turn both TRC (Traction Control) and VCS (Vehicle Stability Control) off. .
                              I was driving on sand last sunday at Kinkuna with the TRC off and still got an alarm beep every time the wheels spun. Now it makes sense. I will try disabling VCS next time I am on sand.
                              thanx
                              Alan.
                              P.S I was fumbling for my keys in the car park the other day with arms full of groveries trying to open the reart door, when my 16 YO daughter said Dad why dont you just press the little black button next to the number plate ops:
                              [color=#0000BF](The MK II) 2012 GXL Auto Diesel, White, ARB Bull Bar, Warn 9500lb XDC Winch, ARB Alloy Roof Rack, Aussieoutdoordirect Awning, Toyota Tow Bar, Safari Snorkel, ORS Rear Drawers and Fridge Slide, ARB Battery System with REDARC isolator, ERPS 10 Pad electronic Rust Cont, 275/65/17 BFG AT's, Jumbuck Sheep Skin Seat Covers, REDARC EBRH Brake Controller, OME 2" lift kit, Air Bag Man high pressure air bags, ARB CKMA12 on board compressor.[/color]
