Sand Driving
  • Sand Driving
    As I am very new to 4x4 driving can I get help with sand driving my new 150 GX, I read somewhere that I should switch something or other(TC?) off before going into loose sdand, I am aware about the tyre pressure bit. Any other basic tips?
    thanks
    Re: Sand Driving
    I've just come back from 10 days on Fraser Island, which is one the best places to visit and to go for sand driving. The last time I was there was 12 years ago in an underpowered 4cyl Pajero. This time couldn't have been more different - the Prado was as easy to drive as anything - whenever the going got a little tougher, it was simply a matter of pressing the accelterator a just a little harder. All I did was to lower the typre pressure to 24 psi, and drove in High Range in the "Select" mode, usually in 3rd gear on the slower bits and 4th gear on the easy beach driving, occasionally I had to use 2nd. Afterwards I washed the car in one of the underneath sprays at Tewantin. On arriving back in Melbourne, I searched the PP forum and elsewhere to get some tips about car care. I have washed the car thoroughly on top, and underneath a couple of times, vacuumed and wiped down the interior. One of the treatments highly recommended is to coat the underneath with a lanolin product, and I have now purchased the Lanotec Heavy Duty product (available from Blackwoods and CBC stores) and am waiting for the weather to change to dry the underneath out before applying the lanolin with a hand spray.
    Fraser Island a terrific spot, we are so lucky being able to drive around it this way.
      Re: Sand Driving
      thanks
      Spend some bucks (around 200) and maybe do a sand driving coarse up at DI, or wait until we hit the beach next time and we will give u some pointers.
      in a prado though, it is fairly basic, tyres down to around low 20's or even 18 if really soft, turn off the Tc if you have it and high range normally in drive is usaully enough. Try and drive on the hard sand and the tide guide is your friend as you don't want to be on the beach too close to high tide coming in or out but particularly coming in. It is fine to go on an outgoing tide as at least you now the water is going out, but if you stick to around 3 hours either side of low tide it is normally alright.
      I suggest though until you are comfortable always travel with someone else.
      DI now has real easy beach access and is a real good training ground as it it is fairly easy.
      It took me well over a dozen beach trips and a Prado to tackle Moreton island on our own, and then i still took some maxtrax's for insurance.
      [b]Rob[/b]
        Re: Sand Driving
        Drop in to your local 4x4 shop and grab Dirty Weekends in South East Qld. Full of great trips around your area but also great for tips. Full of tips on sand and bush driving for beginners. Also as Hutch said above join us on our next PP day to the beach. Best way to learn is to get out and do it. Enjoy.
        Daniel
          Re: Sand Driving
          Gerneral sand driving tips:
          1. Let your tyre pressures down
          2. Only drive directly up and down dunes - never across them!
          3. Momentum is your friend. Keep your speed up(not to make it dangerous of course)
          4. Don't hit the brakes hard unless needed. You will dig in getting bogged easier.
          5. Bring a shovel or some Maxxtraxxs
          6. Dont make any hard turns
          7. Try to stop with the front of the car slighty down hill making it easier to start off again
          8. Don't accelerate off too hard from the start. This will dig you down.
          Those are off the top of my head for now
          enjoy
          J
            Re: Sand Driving
            Just coming back from a 2 days desert trip... and Jonny you said it all.
            I would just add to drop your tyre pressure up to 18 minimum... if you are getting stuck... deflate more ie: 14 or 12 ^si and engage low ratio just to get you out
            As soon as unstuck pump some air back in tyres and go back to High
              Re: Sand Driving
              [quote="Jonny"]Gerneral sand driving tips:
              enjoy
              Thanks fellas, all very good logical advice, pls fill me about the Traction Controll option on the 150 should I switch it off before going on sand? Is there anything else different about the 150 I should know, I have read the manual couple of times but there is no comparision to talking to people with experience.
                Re: Sand Driving
                Turn off TC before hitting the sand because when the car detects wheel slip, it will try to reduce power and this will lead you to getting bogged when what you want is more power to get you out.
                  Re: Sand Driving
                  +1
                    Sand Driving
                    I'd also turn off stability control. When we were on the beach in soft sand at Coffin Bay NP I had traction control off but the stability control still kept going off. You can turn it off by pressing and holding the traction control button for 3 seconds. Then they're both off.
                    Cheers, Sam.
                      Re: Sand Driving
                      Cheers, Sam.
                      I assume that once the engine is turned off the TC and SC are reactivated when the engine is restarted. One more question, do you stay in auto or change over to manual gears. I appreaciate all the good advice received so far its great to have access to so much expertise and yes I will either tag a long with someone experienced or have him/her come along for the first couple of times. Thanks again
                        Sand Driving
                        Yeah I think they reactive once the car is turned off and on. I used the manual mode in deep sand so I could keep it in third gear and easily tap down to second if required.
                          Re: Sand Driving
                          Even with the 4L petrol, I use the Sport mode, they is a better reacion, and I think it is better for the desert driving!
                          Thanks for the stability control tip. I wasnot aware.Great
                            Re: Sand Driving
                            Cheers, Sam.
                            just remember it is almost opposite when you are in L4. VSC is disabled automatically in L4. You have to hold down button for 3 secs to turn off TC
                            Silver 150 GXL V6 Auto: TJM T13 bull bar, Avenger Mako TDS 9.5 winch, 2" lift - Bilstein shocks King springs, factory tow bar, Piranha battery tray, Red Arc isolator, E-Nex DC24MF battery, GME TX3540 UHF, ARB 47L fridge, ARB fridge slide, IPF spotties, Tekonsha P3 brake controller
                              Re: Sand Driving
                              I have an auto, but like using the Triptronic when on sand, allows me to stay in one gear and keep the revs up. I usually travel in high range, 2nd / 3rd BUT in the real soft stuff I'd agree down to LR, and take the TC off. And whatever you do go and spend $275.00 on a set of Maxtrax....I wouldn't go near a beach without them! But I am way short of being an expert so that's just how do it and everyone is an individual.
                              150 Silver Diesel GXL Auto with ECB Bullbar, Toyota Factory towbar, Black Widow Drawer system with Fridge slide and cargo barrier, GME UHF 3340 Radio, Waeco 50 Litre Fridge, Rhino Racks and Rhino Basket, ARB Awning, IPF XS Spotties, ABR Sidewinder Dual Battery system,Airtec Snorkel, Bilstien Shockies, King Springs, Poly Airbags and BFG A/T''s. Now towing a semi offroad Lotus Freelander 18.6 Van, with all the bells and whistles.
