ProVent HP200 Oil Catch Cans
  • #31
    some more info and more pics
    Hi guys
    Here is my opinion on Oil Catch Cans and why fitting them is a good idea (with provisions)
    I wrote this elsewhere so you may see it around.
    The common mistake made when buying an Oil Catch Can is that people are fitting units that reduce the size of the breather tubes. For the professional aftermarket parts developer the mantra is to keep to the same design performance as the OEM manufacturer ... OR BETTER.
    By keeping to this set of guidelines, upgrading your vehicle with after-market parts will not compromise on safety or reliability.
    In this case for Crankcase Ventilation (PCV) Systems keeping to the OEM manufacturer's design rules means having no less an outlet breather tube size than original. Oil catch cans need to be of the same diameter as that of the OEM. There is a reason for this: The manufacturer is concerned with keeping the crankcase free of pressure build up.
    Cheap $40.00 oil catch cans from eBay etc with have tiny 10 -12mm inlets/outlets, or fittings acting as reducers, reduce the flow rates of the PCV System thus causing back-pressure in the crankcase. This build-up of pressure causes engine oil to weep from the crankcase seals etc as they were not made to hold pressure.
    Pound for pound, diesel engines have more blow-by past the rings than petrol engines and thus flow through the PVC System is higher. We certainly do not want to hold back any pressure here.
    I have found one type of Oil Catch Can that fits the bill.
    A GOOD CATCH CAN
    These specially made Hi Performance ProVent HP200 Oil Catch Can do an excellent job of filtering out the oil from the crankcase gasses that are re-entering the engine through the factory setup … and they do this WITHOUT restricting flow.
    In this picture you can see the very large inlet and outlet size. Bigger than any other oil catch can!
    INLET/OUTLETS
    In my opinion, superior to any other style of Oil Catch Can for another reason, it has 2 relief valves. (most other types have none). One is situated on the inlet side to relieve high pressure, the other on the outlet side to relieve any low pressure. Again, this stops any pressure build up even if the filter becomes blocked from you not cleaning it. Its a great engine safe guard!
    RELIEF VALVE
    Keeping the oil out of the air intake will benefit in 2 ways
    Firstly, oil mist in the air intake entering into the combustion chamber will reduce the octane rating of the combustible fuel. Mainly in petrol engines, this leads to a symptom called "pre-ignition". Pre-ignition is one of the quickest ways to damage cylinder heads, piston crowns and piston rings.
    Secondly, (and the main reason) oil entering into the intake manifold combines with the heated gases of the Exhaust Gas Recirculation (EGR) (300-400 deg Cel) and literally bakes to form carbon build-up in the manifold. This carbon build-up, over a relatively short period, restricts the volume of air that would normally be allowed to flow through the manifold into the combustion chamber. (See pictures). The less flow, the less performance. This is well noted on late model Mitsubishi, Toyota and Nissan vehicles.
    Partially Blocked Manifold 1
    Partially Blocked Manifold 2
    Partially Blocked Manifold 3
    The first 3 pictures of manifold above were taken of a late model diesel's intake manifolds having 160,000kms on the clock. (3.2 Litre Mitsubishi Paj)
    This next pic shows a manifold from a vehicle that had less than 70,000kms on the clock
    Partially Blocked Manifold 4
    The next one is a pic from a 200 Series Land Cruiser EGR port showing the soot that comes in (along with the 300- 400 deg temps.)
    What your engine is breathing from the EGR System
    The ProVent HP200 Oil Catch Can has a replaceable element. Maintenance on these is easy too since no actual fittings or pipework is removed to replace / clean filter element.
    The last picture shows a CLEANED intake manifold. (same manifold as shown above in the first 3 pics) If you could start with this and add the Oil Catch Can then this would be best.
    CLEANED MANIFOLD
    Looking at this pic and comparing with the ones above does it look like No 4 cylinder was getting no air at all !!
    This is what I am finding in our modern diesels
    Hope this helps
    Chip It
    Chip Tuning Australia
    • #32
      Thanks Chip-It,
      Having fitted one recently and seeing the results after just a few weeks, I'm disgusted that manufacturers are deliberately sabotaging our engines with their emmisiions reducing techniques. Dont get me wrong, I'm all for wanting a cleaner environment, but these filters should be installed at factory level in all vehicles.
      VXwesty
      [SIZE=1]2011 Crystal Pearl VX D4D Auto, MT ATZ 4 Rib, Full River 105AH / Redarc SBi12 DBS (TJM Tray), CKMA12 Air Comp, Alpine INA-W910R - PDX-5 - Type-R Speakers, Engel MT60FP, Rhino Alloy Platform, Foxwing Awning, Rear 12V Cig and Engel Socket, ARB Deluxe Combi Bar, Safari Snorkel, LF 240 XGT's + HID Upgrade, HB3 (9005) HID Upgrade, Bilstein / Lovells 2" Lift Suspension, Chip-It, Alpine PKG-RSE2 Roof DVD Monitors, Maxtrax, GME TX3540 + AE409L, Avenger TDS 9.5, ARB UVP, ARB Protection Steps.
      [/SIZE]
      • #33
        Hear Hear
        • #34
          Hey Rob, due to all the other bits that I've stuffed into my engine bay, I've really got no room for my ProVent so I've made a bracket that will bolt the can to the left lower side of the bell-housing. This will have the can tucked up above the BD bash plate, alongside the chassis rail and just under the forward edge of the floor pan. That won't put it too far from the rocker cover and cause any issues, will it?
          • #35
            Nope. All OK Dave. Of course dont bash it in. And for this take along a joiner so you can just join the pipes if ever needed.
            Take a pic and post it to show it off.
            • #36
              Rob,
              Do you still have any ProVent HP200 left?
              Thanks.
              Johno
              [CENTER][SIZE=2][B][COLOR=blue][COLOR=blue]150 GXL 2009, T/D Auto [/COLOR][/COLOR][/B][/SIZE][/CENTER]
              • #37
                Yes I am interested too... Do we still get a 20% discount???
                I think it would be a wise mod to do when the new head goes on...
                HERS - KZJ120, BILSTIEN / KINGS, AMTS GEAR, RHINO GEAR, OUTBACK DRAWERS ETC ETC ETC
                • #38
                  AMC head already Drew on your list I see, ha, ha.
                  Yep tehehe... Im looking forward to getting that head on man... And yep beers are non negotiable...
                  • #39
                    hi chaps , new to this get the 150 later this week , Robert would like one of your cans how do i go about it ,whats the procedure, thanks dingdong
                    • #40
                      It's tucked up nice and high and won't get stone chipped. The boys at hydraulink made some custom reducers by crimping stainless 1 inch pipe. All the rubber hoses, clamps and reducers cost me a carton of premium beer, which I might just have to share with to ensure they drink responsibly. I'll do some pics. Thanks.
                      • #41
                        I have them available now for $148. + $18
                        you can order through the store or if you want to pay via EFT send me an email with your name, address, tel. I will reply with an invoice that has banking details attached.
                        • #42
                          Roo who is this you are talking about? I will point people there too.
                          The Purple Pig for the 16mm hose. They have the right EGR hose (R7) for the job. The roll is about 7.6 metres and that will do four members vehicles. The roll cost about $39.00 each, yes that's right, about $5.20 a metre, it's worth sharing.
                          The Roo.
                          • #43
                            thanks for that. Will pass it on
                            • #44
                              I have a small quality (50x) of Provent style Oil Catch Cans. These are on sale for $160.00 plus $18.00 freight.
                              They are a Chip Tuning Brand but same as the Provent 200
                              The reason we stock these is because the outlet/inlet are the same size as the factory diameter. Oil catch cans from eBay etc with reducers to take them to a much smaller diameter inlet can pressurise the sump and cause oil to weep from the crank seals etc.
                              If you forum members are interested I will do a forum special of 20% off for a limited time.
                              Item Code is HP200
                              Click here to see product in store
                              Replacement filters are available
                              They need to be changed out same as the Mann Provent type ... about 20-25K KMS. But if you are careful they can be washed.
                              Pics of the replacement filters can be seen via link below
                              Click here
                              The 20% discount is for 5 days only
                              Robert
                              Can get them delivered to my door for $150......sorry mate.
                              • #45
                                do you live next door?
                                Chip It
