Rear Underbody water tank for 150 Prado
  • #61
    Originally posted by jonoxplor View Post
    Might need a washer to space out the tap, it's not super tight and I'm a little concerned it might back itself out while travelling.
    I'm also going to use either a Lynch pin or R clip to stop the handle from bouncing around on the tap.
    You can buy a 1/2 male to 1/2 female brass fitting from bunnings to space it out. I've got a tee installed for my pump so my tap sits out further than yours. http://www.bunnings.com.au/brass-thr...50116_p4700203
    Otherwise use some plumbers tape to get a good seal and give it some resistance to stop it moving.
    I noticed you chose not to extend the breathers up any higher. With a full tank the water might leak out a bit if you are on an angle.
    Did you notice the little red bit of plastic. It was meant to go inside the water level tube to make it easier to see the level.
    Good to see the tank installed. Hope you get good use of it.
    • #62
      I was going to fit a Wynnum tow bar fitted in the next week but now after seeing this tank I might go back to plan A and fit the Toyota bar so I can put a tank in. Looks really good
      • #63
        All good ideas... and I have no idea where the red plastic went... crap.
        I did wrap the tap with plumbers tape, I probably need to do a few more wraps to get it tighter, but it was water tight.
        Thanks again mate, I'll let you know what my discoveries are.
        [url="http://www.pradopoint.com/showthread.php?31511-Jono-s-MY14-GXL"]My Rig Build Up[/url]
        • #64
          Instructions for fitting Tin’s water tank.
          1. Unbolt the 2 plastic pieces from behind the tow bar, you will have to remove the cover where the tow bar goes through the bumper bar to access the middle bolts. The tank hangs from the outside bolts that the plastic pieces were bolted too. At this stage make sure any wiring for trailer plugs, air bags etc is out of the road or has plenty of slack to allow for fitting of the tank.
          2. Bolt the mounting brackets to the tank, they hang down and outwards, don’t tighten until in position, you need a little bit of wiggle room when fitting the tank. Fit the hose fittings for the level indicator and breathers.
          3. I found it easier to remove the tow bar mounting bolts on one side, so you could slide the mount for one side over the bolts, push the tank up into position and the fit the bolts for the other side. Wiggle the tank around until you are happy with the position and then tighten all mounting bolts.
          4. Run and connect the pipe work for the breathers, filler and outlet. I already had a small water tank fitted, so I just rerouted the pipes. I joined the two breathers together and just had a single breather pipe. I had a larger 1 inch outlet fitted to my tank, so I used this as a combined filler and outlet.
          4WDriver since 1975, current 4WD, 2009 GX diesel auto 150 series, fitted with ARB bullbar, snokel, dual batteries, rear draws, water tank, mud tyres, side steps, 50mm lift & roof bars. Tow a Olympic Champion XPack caravan, travelled a lot of Australia, past big trips in 150, August 2010 - Hay River Track NT, July 2011 - Kimberleys and WA, July 2013 - Canning Stock Route WA.
          • #65
            Hi Electron
            Don't get those fillers http://postimg.org/image/sr1ea9zhz/ mixed up will you!
            • #66
              Once when I filling the water tank in the front yard, some body walking down the street wanted to know how well the car ran on water. Some others think it is for gas tank filling.
              • #67
                Tell them its for filling the Bio Diesel tank, just need to find enough lizards to make the special Goanna oil!
                • #68
                  Great looking design! I was just about to go down a similar path - message sent, and hoping I'm not too late to put my hand up for one.
                  I'll give you the "Kalgoorlie" feed back. If it survive here it will survive anywhere
                  • #69
                    Just letting everyone know I got a tank off Tin last week. Fitted it up with no dramas, straight bolt up job looks mint and there is simply no room for improvement very happy.
                    • #70
                      Thanks for the kind words. I trust it will come in handy the next time you are on the beach.
                      I still have a couple left from the last batch if anyone else wants one.
                      • #71
                        Hi Tin
                        I've got a kaymar rear bar and would be very, very interested if it suits. Awesome job.
                        • #72
                          Has anyone done a lot of kms or been off road yet with their tank fitted, any problems?
                          Ron
                          • #73
                            Ron
                            I have done three or four full day off road trips with no issues at all, clearance is not an problem as it sit up neatly between the sub tank and tow bar. Also have done the syd to adel still sitting in nicely no rattles or noises. All good!!
                            • #74
                              Originally posted by Frankmoli View Post
                              Hi Tin
                              I can reply on Tin's behalf, it won't fit. We had a look with mine and the kaymar has bracing right where the tank sits. When you find something that fits let me know.
                              [LEFT]Silver 150 Facelift
                              • #75
                                Sorry, it won't fit with a kaymar rear bar.
                                I've had my tank installed since February. I've done 14,000 km. I've been on 3 or 4 off road day trips, a few days on Moreton and up to Fraser with the camper trailer for 4 days. My tank is always at least half full. I had a good look at it a couple of weeks ago and it looks fine.
