Altitude Cargo Barrier measurements
  • Altitude Cargo Barrier measurements
    Hello , If someone has the time to take a quick measurement for me please that has the same / similar setup as discussed.
    I have a May 2012 - 7 seat Altitude and i intend on installing drifta rear draws into and also a cargo barrier , If i guessing correctly then cargo barrier is unique because of airbags etc so its a different measurement to standard GXL models . I am chasing the measurements so i can search for the correct barrier required.
    Appreciate your help in advance
    Drifta do sell a cargo barrier to suit their drawer systems. Typically a half height barrier made by Autosafe. Send an email to beechy at drifta about them. [email protected]
      Exactly and it sits above your drawers not in front so you don't lose that 30mm which may result in the draws not fitting lengthwise
      Matt
      Rig build here
        And a GXL has the same airbags as a Altitude in the rear, as does a VX, a Kakadu and a 7 seat GX, only the 5 seat GX misses out on the airbags you are referring too.
        [LEFT]Silver 150 Facelift
