Drifta Drawers and Fold out table
  • Drifta Drawers and Fold out table
    Hi All
    I am about to press go on a set of Drifta drawers for the back of the 150 and have already installed a drop down table.
    I am hoping not to have a clash between the two.
    I am hoping to get two full sized drawers and not their table as I already have the one on the rear door.
    Just wondering if anyone has got both.
    Thanks for looking and to those who respond.
    James
    2014 GXL Prado
    From a Galaxy Far Far Away
    Hey mate , I have a 120 & drifta draws with rear door table & it fits ok. I have used 16mm laminated board and carpet on the outside & the draws leave a small imprint in the carpet. Pretty tight but will fit with table & cargo barrier. I wasnt going to get the card table either but glad i changed my mind. Great to have when camping with no trailer & eating lunch or cooking.
    Cheers Matt
    Sent from my SM-J110F using Tapatalk
    Rig build here
      I have a set of Drifta drawers in my GXL 150 and by memory there is maybe a 20mm gap (I'll double check for you). That being said the way the drawers mount to the false floor moving them back a few mm would be no issue. The false floor comes with 8 pre-drilled holes that match up with 8 pre-drilled holes on the drawers. Drifta are a good mob and if you ask they will not put the holes in the false floor so you can position and drill your own if needed.
        Hi JimmyC
        Thanks for the info, if you could when you get a chance take a quick measurement that would be great.
        Plus I will ask them what are their thoughts as well, leave the positioning to me etc.
        2014 GXL Prado
          Thanks Mattfunk 120.
          Mine is 15mm marine ply with carpet on both sides and the black plastic hinges.
          I dont care if there is an impression.
          2014 GXL Prado
            I'm curious myself because I have the drawers in now and want to put a table in.
              Drifta will customise your drawers for you. So if you want them a bit shorter to give you more space, they will do that. Mine are 10mm shorter than standard due to my cargo barrier
              I've got the pull out table on mine with no door table. Its a bit more versatile than the door mounted on in my opinion. I find it really handy because it can be pulled out part way and used like the rear door table. OR you can pull it out and use it around camp.
              But if you need the extra height in the drawers I can see why you'd go for the door mount.
                Like the taco ad says: Why not have both?
                  Originally posted by r2d2 View Post
                  Hi JimmyC
                  Had a look using extremely scientific methods (opened both drawers slightly, closed door and saw how much drawer was left poking out) and it's about 22-23mm gap
