has anyone mounted inner guard liner to outer arb splash tray
Maybe a piece of alloy strip with nutserts in it on the inside and machine screws from the tyre side through the steel guard, sandwich the plastic and into the alloy strip. That would hold it in a similar position as now but tight against the steel lip. No mud and no less clearance (except the little machine screw heads).[LEFT]Silver 150 Facelift
Mine on a TJM bar where both just sitting there. Was installed by toyota so not really surprised. Both sides rattled badly, they drilled a hole and cable tied through the steel guard and plastic liner. I thought it was dodgy but it has fixed the rattle and allows a bit of movement still. I was going to use some of those little u shaped trim clips that hold with a self tapping screw, I think I'll leave the cable ties and see how they hold up.
Cheers, Nova
If you do fix it solidly, the plastic guard will just pull off with the flex of the guard being different to the flex of the body. Mine are screwed with teck screws but I have to refix the guard every now and then.
Ron4WDriver since 1975, current 4WD, 2009 GX diesel auto 150 series, fitted with ARB bullbar, snokel, dual batteries, rear draws, water tank, mud tyres, side steps, 50mm lift & roof bars. Tow a Olympic Champion XPack caravan, travelled a lot of Australia, past big trips in 150, August 2010 - Hay River Track NT, July 2011 - Kimberleys and WA, July 2013 - Canning Stock Route WA.
