Finally got around to knocking up a false floor to attach our fridge slide to in preparation for our Eyre Peninsula trip in September.
I made the floor out of ply and covered it with an indoor/outdoor carpet from Clark Rubber. the shape was easy enough as I could just trace the Toyota factory rubber mat. Unfortunately the 900 x 1200 piece of ply I bought wasn't quite wide enough at the very rear, hence the small gaps. Still looks pretty good though.
I secured it to the floor using the existing captive nuts that hold the tie down hooks in and longer M6 bolts and large washers.
I then screwed the fridge slide in place using some 15mm screws.
Came up really well and is very secure.
I'll leave the fridge slide attached to the floor and pull the whole lot out as one when not in use. Then it's just a 5 minute job to pop it back in for trips.
Cheers, Sam.
Cheers, Sam.
