Do you know roughly what they did at the rear or did they raise the front 35mm and let the rear just self level?
Anyone had success with Kakadu susp mods ?
Originally posted by KAKADAZ View PostDo you know roughly what they did at the rear or did they raise the front 35mm and let the rear just self level?2010 Kakadu, ARB Deluxe Bar, Lightforce HID's, Koni Shocks, King Springs, Safari Snorkel, Twin Battery System, Diff Breathers, GME TX3540 Remote Head UHF, BFG' s; Fourby Fitout drawer system
Originally posted by pwop View PostNo I don't know much of what they did. VERY friendly guys and I don't think they will mind if one phones and asks.2010 Kakadu with all the usual stuff.... Build up thread below
Powp
Did you lose any of the functions of the Kakadu. Namely the variable suspension option?
I look forward to your measurements
Ken2010 150 D4D Kakadu, Graphite, Toyota tow bar, Tint, Mats, Headlight Protectors, Redarc dual battery and Brake controller,Sahara Bar,Safari Snorkel,Icom440,OME suspension,Steinbauer module,Genesis HID lights.
Originally posted by KAKADAZ View PostAre they in Vic mate ?2010 Kakadu, ARB Deluxe Bar, Lightforce HID's, Koni Shocks, King Springs, Safari Snorkel, Twin Battery System, Diff Breathers, GME TX3540 Remote Head UHF, BFG' s; Fourby Fitout drawer system
Ken,
Only the Comfort/Sport mode obviously but absolutely nothing else. Heard many stories of some needing the computer re-setting as they were displaying lights on the dash and reporting fault codes, but even if this were correct it's nothing for Toyota to re-set it. I have had nothing change whatsoever, nor any lean issues. SWTSMBO has taken the car till Sunday but when it returns I'll get the measurements for you. From memory it was a good two & a half inches, with the front crossmember ground clearance being the most obvious improvement.
Mick
Thanks Mick. I had the same experience. The comfort setting but everything else OK. Except for the lean. Look forward to your post
ken2010 150 D4D Kakadu, Graphite, Toyota tow bar, Tint, Mats, Headlight Protectors, Redarc dual battery and Brake controller,Sahara Bar,Safari Snorkel,Icom440,OME suspension,Steinbauer module,Genesis HID lights.
Originally posted by KJA View PostPwop,
Could you elaborate a little more please. What upgrade did you have fitted? Did the vehicle have a lean before the lift or did Guest4WD just ensure there was none after the installation? I still have my lean that comes and goes. Do you know what they did to ensure there was no lean? If you have time I would love to know the measurements from the bottom of the rim to the bottom of the guard on each wheel. When level mine are: rear 890mm and front 820mm.
Ken2010 Kakadu, ARB Deluxe Bar, Lightforce HID's, Koni Shocks, King Springs, Safari Snorkel, Twin Battery System, Diff Breathers, GME TX3540 Remote Head UHF, BFG' s; Fourby Fitout drawer system
Originally posted by MadMick View PostFinally got around to it.
Mine came in at 805mm front and 800mm rear. No lean at all.
Mick2010 Kakadu with all the usual stuff.... Build up thread below
Kakadaz
I am absolutely confused. I can't believe the above measurements. It seems the measurements are around 800mm where as mine come in at 870mm and 890mm. If Madmick and Powp have had a 2" lift then mine must be 6"!!!! Can you measure your truck that has not been lifted and give me a basis to work from. I am measuring from the bottom of the wheel rim to the bottom of the wheel arc in a perpendicular. I believed my lift was about 3 to 4". I am now worried about insurance. Do I have to notify the road traffic authority about the lift - is it a modification that needs to be approved?2010 150 D4D Kakadu, Graphite, Toyota tow bar, Tint, Mats, Headlight Protectors, Redarc dual battery and Brake controller,Sahara Bar,Safari Snorkel,Icom440,OME suspension,Steinbauer module,Genesis HID lights.
Originally posted by KJA View PostKakadaz
I am absolutely confused. I can't believe the above measurements. It seems the measurements are around 800mm where as mine come in at 870mm and 890mm. If Madmick and Powp have had a 2" lift then mine must be 6"!!!! Can you measure your truck that has not been lifted and give me a basis to work from. I am measuring from the bottom of the wheel rim to the bottom of the wheel arc in a perpendicular. I believed my lift was about 3 to 4". I am now worried about insurance. Do I have to notify the road traffic authority about the lift - is it a modification that needs to be approved?Last edited by KAKADAZ; 28-07-2011, 09:49 PM.2010 Kakadu with all the usual stuff.... Build up thread below
