Hi guys
I returned from a 750 km weekend( all blacktop) and noticed some wear on the outside of both front tyres.
The Yoko ATS tyres have only done 5k. I have ironman constant lift and steel b.bar.
The tyre guy said alignment and rotation- obvious solution. But at a previous wheel alignment done in SA the guy said that because of the lift kit, he was unable to get the camber and castor back to factory specs.
I went for the constant lift rather than the one below on the advice of the 4x4 store in Wagga and the Ironman tech dept as I intended to put more weight on through accessories. The inevitable happened and the $ dried up! I can live with that issue for a while, just don't want to cause unnecessary wear on tyres, which will in the end cost more money and push the winch, roofrack, fridge and camper trailer further away.
I have 2 thoughts on the matter
1 put more weight (winch) in the front of the car to compress the suspension and get more play in the camber and castor adjustment.... Would this work?
2 Replace some suspension components to allow for greater adjustability in the camber and castor. What components would I need to replace?
I have very limited knowledge and a solution soon, any suggestions?
Thanks in advance.
Thanks in advance.
