Similar to the 120 Suspension measurement, thought we should start one for 150`s.
I notice that measurements are from the bottom lip of the rim of the wheel through the centre of wheel to the guard, which is a good measurement as long as we are talking the same wheels.
I think more accurate would be too measure from centre of wheel to the guard or just deduct wheel radius; ie half the distance when measuring from rim to rim. Just allows for people that have fitted different diameter wheels.
It would be nice to get consistent results with the same amount of fuel onboard, but that is a bit too much to ask, mine are with around 3/4 off a tank full.
ie front measure for my 150 standard when new was about 76.5cm from bottom rim or 53cm measured form centre and rear 78.5cm or 55cm.
Would like a number of measurement from standard right through to 150`s that have had accessories and also various springs and shocks fitted.
Left and right measurements have typically been within 5mm so I haven`t bothered with listing both, just averaged them
F 76.5 ( 53 ) new, no accessories all standard.
R 78.5 ( 55 )
F 76 ( 52.5 ) with dual battery ~30kg and ~ 30kg of Hayman reese towbar and 15000km.
R 78 ( 54.5 )
R 78.5 ( 55 )
R 78 ( 54.5 )
