Feed back please needed
  • Feed back please needed
    Hello all
    I know there is a lot of good info on here but all I can see is older posts looking at suspension toss up between Tough Dog and the Gold TJM
    I have TJM winch bar, winch, dual battery's fitted to front and ARB rear draws fitted in back.
    As I said looking at the tough dog and TJM setup I use the truck off road and want it to work well so I guess I'm after flex a little more than on road comfort tyre size is 265. 70. 17s
    Cheers.
    There are similar threads to this if you search. I have XGS gold and I am happy with it.
      Sorry to be a pain but I've had no luck been looking for the last 2 days only found 2 threads any help in a link would be great
        The sites search function is not so good.
        The trick is to use google.
        For example - Type pradopoint:suspension into google and it will get better results.
          Petrol or diesel? Have a look at Hutch's build if you have a petrol. Good advice from Beach I only google search these days unless I know where the thread is.
            Cheers for the help I have diesel
              Ive got a diesel 150 with Bar, Winch, Dual Battery, Spotties, Air Compressor, etc all over the front wheels. My factory shocks went to crap around 30,000km. I replaced them with Adjustable Tough Dog Front/Rear w/ Additional addon of Polyair airbags in the back incase i need to correct the ride height with heavy towing.
              Now up to 77,000 and I've had zero problems with them. Run them usually around 5 at the front, and 6/7 at the rear. Couldnt be happier.
                Thanks Ryzz any chance of some side on pictures so I can see ride height?
                  Ill run outside and grab one quickly, i only seem to have video footage of the Prado since the suspension went in.
                    Thanks Ryzz that would be great
                      Hey mate
                      I have a diesel gxl with steel bar, dual batts, roof rack, black widow drawers, 32 inch light bar and a compressor (rear mounted). I got sick of the wallowing and went with the tjm gold setup (heavy front,med rear) and am very happy. It's taken most of the wallowing out and has given me a bit more height. I haven't done any real serious trips yet but so far(~10,000 km) I'm very happy.
                      Adam
                        TJM heavy front med rear very happy.
                        [b]Rob[/b]
                          TJM heavy front and rear also very happy.
                          REV Prado 150 also with some TJM kit and ARB and Opposite Lock and an empty bank account.
                            Both are very good products & you won't go wrong with either..
                            The Tough dog has the option of Adjustable shocks, so you can wind them down for day to day comfort & crank them up when fully loaded to help keep the body roll in check.
                            Regards, Jason.
                              Sorry for the delay in getting the picture up.
                              Keep in mind this is a slanted driveway so the car is on a lean. Best photo I could get at the time sorry.
