Hi Guys, wondering if anyone has also had the King Springs fitted for a 2" lift with the KDSS ?I have them fitted with Bilstein shocks
Front - KTFR 121
Rear - KTRR 102
The R/H front spring is a few mm longer than the L/H about 12mm I think, to compensate for the KDSS lean. only problem is after a few good 4x4 tracks it now has a 20mm lean to the R/H front. I called up the shop to let them know and tell them I wanted to bring it back inj to have the front R/H spring set adjustment raised 1 slot ( the reason I got the bilsteins) and was told by them that " its impossible to have that much and that the car must be on uneven ground ", as you could imagine I was not happy with that response, in fact it made me pretty Pissed off to be treated like an idiot hwen I had clearly done more research on the subject than them. Any way I called King Spring and was informed that they have never heard of a lean of that much with these new springs as they are designed for the KDSS models.
So was wondering if anyone else has had this issue with the new King Springs?
cheers , Matt
Front - KTFR 121
Rear - KTRR 102
cheers , Matt
