I better read the rules of posting first so I'll retract this post and look over others in case I find an answer that way
Standard springs with steel bar
G'day neighbour! What other plans do you have? If you are fitting a winch and/or dual batteries definitely you need new springs. Ideally you should fit new springs with the bar but as a bar will only add 50kg or so you could get away with it but not forever. If you want to keep standard height a few suppliers can do heavier duty springs and standard height.
Have a look in the 150 suspension thread about suppliers and ride heights. Don't forget to go to the introductions thread and tell us about your Prado and plans.
MichaelMy 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Originally posted by luvwood View PostI better read the rules of posting first so I'll retract this post and look over others in case I find an answer that way
Kings and most other brands have a heavier rate STD height spring for what you need.
You could probably leave the stock ones initially, but the front will creep down over time with the additional weight.
I left my stock ones initially with my Ironman steel bar, didn't really pay attention for a while, then walked out the front one day about 6 months later & went oh!
Regards, Jason.
