Hi all
I have recently installed a 2" lift in my 150. Looking at the wheel alignment specs, it tells me the factory caster should be 2.45deg +- .45deg. My height is about 795 - 800mm. After the lift, I have only .43 deg on the right and 1.25 deg on the left.
I came from a live axle Jeep where caster is so important and low caster lead to all sorts of front end issues.
So how important is caster in a an IFS vehicle. Looking at other posts, I see that most people have similar specs after a lift.
Should we all be looking at upper arms. If cost was not an factor, should we be looking at UCA's, or it doesn't really matter.
Be great for some of the vendors to chime in here.
