Kakadu Rear suspension lift
  • Kakadu Rear suspension lift
    Hi All,
    I'm having new front struts installed and was going to install spacers on the rear levelling arms to raise the bags. Does anyone know if there is a particular process for fitting the spacers under the arms and what size do you recommend to compliment a 50mm front lift? Do you also recommend fitting spacers under the airbags themselves?
    cheers
    Geoff
    2012 Kakadu V6 - Graphite, Opposite Lock Bar, Hella Rallye 4000, GME 3440, Scangauge, Featherlite Awning, TG150 Guard, Traxide UC160 Dual Battery system and 2 Yellowtop batts, Safari Snorkel, Bushskinz bash plates, 2" suspension lift, 3D mats
    Mods to come - Front locker, Runva 11XP winch, 265/65R18
    The ratio is about 1:3
    http://www.pradopoint.com/showthread...r-a-Lift/page5
    I would fit airbag spacers to prevent over extension and to correct the airbag angle after a lift.
